20 psi of oil pressure(even with higher rpms)
Old Mar 21, 2007 | 11:39 AM
Brandon94Z28's Avatar
Well I put a f-body LT1 into my 95 Imp SS. The oil pressure would go up to twenty psi and wouldn't go up with higher rpms. Do you think this is caused by a bad oil pump? I found out the motor I bought had a blown head gasket after 10 minutes of run time so I have to tear it back down anyway. Might as well throw a new pump in. Is there a way to check an oil pump without taking it out?
Brandon
Old Mar 21, 2007 | 03:36 PM
exgmguy's Avatar
Are you relying on the factory gauge? If so, try testing it with a mechanical gauge first.
Old Mar 21, 2007 | 04:22 PM
mrmint69's Avatar
I would replace it anyways. I hate to leave those kind of parts and then worry about them later on.
Old Mar 21, 2007 | 04:25 PM
mdenz3's Avatar
i agree, better safe than sorry, and get one of the "white" springs for the pump.
Old Mar 21, 2007 | 04:31 PM
Ya I think I am going to throw a new one in just to be safe.
thanks guys
Brandon
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Cam's maro
Mar 24, 2015 08:09 PM
jayblev95
Dec 1, 2014 06:55 AM
