clutch safety switch
Old Jul 13, 2003 | 12:19 AM
Black Beauty's Avatar
i bought what i thought was a clutch safety switch but it doesnt look right. its kinda rectangular shaped instead of spark plug shaped. anyone got a part number for the clutch safety switch?
thanks!
Old Jul 13, 2003 | 12:24 AM
GM PART # 14094368
Old Jul 13, 2003 | 12:29 AM
what does it look like...thats what i ordered....
Old Jul 13, 2003 | 12:54 AM
try it now
Old Jul 13, 2003 | 08:24 AM
Can't view your photo...
Old Jul 13, 2003 | 08:42 AM
scoobysnax83's Avatar
that looks like it to me. What is the problem? Where did you get the switch?
Old Jul 13, 2003 | 10:33 AM
wicked_95z's Avatar
Mine was rectangular also. Just wire the two together and call it a day. That switch used to drive me nutz
Old Jul 13, 2003 | 12:16 PM
there is no continuity when the button is not pressed. (open circuit)
there is continuity when it is pressed (0 ohms resistance). (closed circuit)
is this how the switch is supposed to function. i thought it would be the other way around.
Old Jul 13, 2003 | 04:51 PM
its fine.....
they probably do that just so that you can't splice the wires together and bypass the switch without extra work.
Old Jul 15, 2003 | 10:05 PM
i recently realized how it mounted up. there are the 2 eyelets in the back of the clutch pedal housing where the switch slips into and a small spring slips into a small hole in the back locking it into place. the button faces toward the driver so that when he/she presses the pedal it will contact the switch giving the starter solenoid a complete circuit so that you can start it.
now if only i could figure out how to hook up this purple wire and tan wire to the switch. is there someway to solder it?
Old Jul 16, 2003 | 12:19 AM
awad2000's Avatar
So you could rig the button somewhere else hidden as a Security feature so you were the only one to know how to start the car?
Old Jul 16, 2003 | 09:09 AM
Sure. In essence, you would just be relocating the clutch safety switch.
Old Jul 16, 2003 | 12:19 PM
awad2000's Avatar
yes, exactly. That sounds pretty cool.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
mrwz28
Jul 8, 2015 09:11 PM
HectorM52
Jan 30, 2015 11:08 PM
kandied91z
Aug 4, 2002 02:53 AM
