Clunking/squeaking from the rear
Old Apr 9, 2003 | 09:55 AM
95_RipperZ's Avatar
Driving around I am always hearing a loud clunking/squeaking when I go over bumps or come out of a driveway it is real bad. It sounds like it is the rear passenger shock or spring. Regualr driving seems to be ok and the bumps will do it occassionally but when I do up into a driveway or out of one (or parking lots) the noise is just ridiculous.
Is it time for new shocks/springs?
Car has 42k on it.
Old Apr 9, 2003 | 10:47 AM
cals400ex's Avatar
mine does the same thing. however, in my case, it is my drivers side lower control arm. i think i just need new bushing. if i oil them, the noise stops but comes back in a few weeks.
Old Apr 9, 2003 | 04:36 PM
pu12en12g's Avatar
TTT
I have the same problem... It got ALOT worse after my BMR suspension stuff and coilover setup...
Old Apr 9, 2003 | 07:39 PM
95_RipperZ's Avatar
Originally posted by pu12en12g
TTT
I don't have any of the suspension pieces put in yet but I will. Did you have it before or just after? What all did you install? I have SFCs, LCAs, and the relocation brackets at home waiting to be put in.
It only started this year too. I don't even recall it last year and I could swear it is the shock or spring. Maybe a set of Hals will be the next mod.
In my case I do not think that an LCA can make that much noise. It really is loud. Maybe I will get a tape recorder and get some sounds of it.
Old Apr 9, 2003 | 07:47 PM
mortal z28's Avatar
hey same problem here on my 95 z with 85k miles.. i oil and oil but yeah after a few weeks it comes right back.. its gotta be the bushings
Old Apr 9, 2003 | 07:49 PM
mortal z28's Avatar
..oh one other thing.. i used to notice a loud clunking and one day i took apart the back to find that the jack was loose so i just wrapped it up in a towel and tightened it down
Old Apr 9, 2003 | 07:54 PM
pu12en12g's Avatar
I installed Tubular Welded SFCs, STB, front and rear sway bars (ALL BMR), and Ground-Control coilovers.. my suspension squeaks over light bumps/turns, and clunks over heavy bumps/turns.
The squeaking got ALOT worse after leaving my car on jackstands overnight one time...
95_RipperZ's Avatar
Well it isn't the jack. I have the !jack mod.
Old Apr 9, 2003 | 08:25 PM
pu12en12g's Avatar
me 2
Old Apr 9, 2003 | 08:31 PM
Rx-7 SS's Avatar
Just to throw in another couple cents to the pot--> check out your exhaust clearances. Both my friend and I had 91 talons (mine since traded ) but both of us wouls swear we had something wrong with our passenger rear suspension, BOTH turned out to be exhaust rubbing (only really did on bumpy roads or curbs etc.). Ive heard my share of clunky suspensions, and I would SWEAR its about identical.
Old Apr 10, 2003 | 12:18 AM
cals400ex's Avatar
here is what i did. i went the the drivers sider rear fenderwell and started bouncing it up and down so i could pinpoint the noise. in my case, it turned out to be the lca. on my car it makes a rather loud clunking noise with the right bumps. try to bounce your back end up and down and see if you can hear it. you can do it like i did one side at a time if its hard to tell from bouncing the whole rear.
Old Apr 10, 2003 | 06:07 AM
BigEvil's Avatar
Agree, that's the best way to find the problem.
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
