clunk
Old Aug 4, 2003 | 10:35 PM
oaklandz28's Avatar
clunk
i hear a big clunk every now and then from the rear. what is it and how do i get rid of it?
Old Aug 4, 2003 | 11:20 PM
ZDriver96's Avatar
2 torque arm bolts that hold it to your rear end. Make sure they are tight. Clunk when you hit the gas pretty good.. but if u hit the gas again they usually want clunk cuz it seated itself all the way back, clunk again if u brake hard.. etc
U-joints on the driveshaft could cause it.
Old Aug 5, 2003 | 12:43 AM
Cmr0z28's Avatar
let's not forget the tranny mount.....the stock rubber piece is a mushy piece of **** that will deteriorate after awhile. also, if it only does it when making turns, it's your posi.
Old Aug 5, 2003 | 12:55 AM
Zack's Avatar
i get a clunk often after i let off the the gas quickly. Im guessing its my exhaust system since I did have it removed before. what kinda clunk is it, becuase mine is a hollow sounding one
ford
May 8, 2003 08:15 PM
mike95z28
May 1, 2003 11:13 PM
Smokn '94 Z
Mar 25, 2003 09:00 PM
Achilles97
Mar 18, 2003 11:56 PM
SpecForceZ28
Mar 10, 2003 01:28 AM
