Clueless
Old Jan 19, 2012 | 11:06 AM
Grizz's Avatar
Clueless
ive been told that my Z has a flat cam and i need to replace, first of all ive never heard of this and idk if this happens a lot so if u guys could throw some light on that... 2nd if i do i want to put a better cam in it.. i have absolutely no idea on what size and/or what all i will need to get the job done. i would like to gain hp from the ordeal but it is also my daily driver in the summer. pls help =]
Old Jan 19, 2012 | 02:34 PM
Tech's Avatar
Re: Clueless
Not a common problem. GM hotcam is budget friendly and streetable.
Old Jan 19, 2012 | 03:23 PM
Guest47904's Avatar
Guest
Re: Clueless
Not likely. All SBC after 1987 had roller lifters. It's easy to find out. Remove a valve cover and check the movement of the rocker arms.
Second, if the cam lobes were warn down, you would have a gap or movement between the pushrod and the rocker. SEVERE noise would be heard also.
Old Jan 20, 2012 | 10:38 AM
Grizz's Avatar
Re: Clueless
ok thanks what size would i get to see hp gain and maintain driveability
and i thought so to speedy. the rerason my car wont run i believe is my opti
Old Jan 20, 2012 | 02:39 PM
Guest47904's Avatar
Guest
Re: Clueless
Another thing, you would have no compression in the cylinders that have warn lobes.
blkWidow
Sep 6, 2015 05:17 PM
chrisheather94
Jun 20, 2015 08:49 AM
mooleyz28
Oct 2, 2003 12:02 PM
JamesN1830
Jul 17, 2003 09:59 AM
Hotwire
Jun 29, 2003 10:50 PM
