Closed loop....then dies!!!
Old Oct 27, 2005 | 01:42 PM
  #31
turbo_Z's Avatar
Re: Closed loop....then dies!!!
The opti fires the injectors and the plugs so if the PCM loses 1 of the 2 signals then the motor is gonna stall out. Did you ever try the old paperclip trick to see what codes come up?
Old Oct 27, 2005 | 02:24 PM
  #32
marshall93z's Avatar
Yep.
Not jumping on you or anyting, but I have mentioned a couple times already that no codes are being thrown. I checked it and could NOT believe that "12" kept flashing over and over and over!
Old Oct 27, 2005 | 02:44 PM
  #33
Alvin@pcmforless.com's Avatar
i would put a coil on it first.
They are cheap... i've even got a few laying around.
When they get hot you can sperate a weak contact in the inductor. Hit a bump and bam.. its off and your not running any more
PS.. you plan on going to the track tonight? I think I finally got a belt to fit half way decent.. I also got some really nice looking heat wrap around my aftercooler..
Old Oct 27, 2005 | 02:46 PM
  #34
I have already put a coil and ICM on it.
Yeah, I'll be there, but not in my Camaro!
Old Oct 27, 2005 | 02:51 PM
  #35
only 2 things left then.. optispark or opti harness...
awesome.. I hope it ain't so crowded and I can pull off a good run or two.
Old Nov 20, 2005 | 05:36 PM
  #36
UPDATE!!!!!!!!
I changed the opti harness and the car hasn't missed a beat!!
Runs different than it ever has before. Now when I start it up, it will idle sorta high (1000-1200) then settle down after about 20 seconds to 850 or so!! It has NEVER done that....as far as I can remember.
It also starts ALOT easier now!!
Old Nov 21, 2005 | 08:43 PM
  #37
BLK96Z28's Avatar
Where did you get the opti harness? My cars doing the EXACT same thing.
Old Nov 21, 2005 | 09:09 PM
  #38
I have another LT1 car that I stole it from. I hear that it is over 100 buck for the damn thing!
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
Toxintwins
Sep 11, 2015 11:13 AM
