Closed Loop A/F
Closed Loop A/F
I know the pcm tries to keep it at 14.7. It does this to reduce emissions not that it is the best ratio for fuel economy or performance (open loop is much more important to performance I'll be running 13:1 there).
My question is (without running widebands) is there a way to have the car run leaner than 14.7 in closed loop (like tricking the computer/ tuning etc.)??
Re: Closed Loop A/F
Problem is the O2s are accurate ONLY at that 14.7. You CAN make it run at a different AFR BUT you need to know what you are doing and need a wideband to monitor it at least during tuning. Rumor has it there are lean highway cruise tables in the pcm accessible if you get into hex editting. That is about all I know about it though. I know it exists and a little of what it can do but don't know how to get into it yet.
Re: Closed Loop A/F
tommalcolm
Sep 11, 2015 03:39 PM
Toxintwins
Sep 11, 2015 11:13 AM
tdigger9899
Sep 7, 2015 10:56 AM
