Clearancing the rods for cam
Old Feb 17, 2006 | 01:16 PM
97WS6NY's Avatar
I am having a short block (383) built w/ eagle forged 4340 crank, eagle 4340 forged h-beam rods, and -5cc srp flat top pistons. I am wondering from other people using the same rods, did you have to have them clearanced for large cams (like .620 lift w/1.6RRs)? Just wanna make sure I have it done if it is necessary. Thanks
Old Feb 17, 2006 | 01:23 PM
96LT1TX's Avatar
Re: Clearancing the rods for cam
I am interested in the same thing, I have a 383 in the works myself, 4340 eagly crank, hbeam rods too. My cam is in sig, .545/.555 lift. I was told that you should be more worried about the inner diameter of the cam, and not the lobes themselves. The machine shop that cleaned my block said the inner diameter needs to be for a 383, havent called comp yet to see if my cam will work; maybe that is next if no one replies here.
Old Feb 17, 2006 | 01:28 PM
97WS6NY's Avatar
Yeah I am waiting also to find out what size base circle it was ground on.
Old Feb 17, 2006 | 02:21 PM
WS Sick's Avatar
Yeah its usually the back side of an exhaust lobe that comes the closest. The only real way to find out is to mock up the engine and turn it over, grind where needed. The clearancing should be done BEFORE you have it balanced.
In my case with eagle I beam rods I needed no clearancing, and on the other hand a guy here used the same rods as me and had to remove a little.
Old Feb 17, 2006 | 04:28 PM
NVetro's Avatar
on my 383 build my engine shop has to clearence the rod abit on the side, it was hittting the lobes on my cam. I went with callies 5.7" compstar rods and a custom cam from bret bauer. I also went with a callies dragonslayer crank and the rear of the block had to be notched for the counter weight, all common stuff with a 383/396 build. some have issues some dont...all depends on what parts you use, its not a bad thing that you mite need clearence
Old Feb 17, 2006 | 05:36 PM
1racerdude's Avatar
Ya may have to get a small base circle cam AND clearence the rods. If ya don't get a small base cam(.950) made on a billet core, ya may have to grind the rods to much and weaken the to the point of breaking under RPM's. UGLY MESS.
Ya should let your machine shop do it 'cause they have probably done more than one rod/set and know where to grind and how much.
Old Feb 17, 2006 | 06:33 PM
97WS6NY's Avatar
Actually I just talked to them, cam is ground on a .940 base circle, and they said that we would just go ahead and use the k-cut h-beams as they are already clearanced for a 4" stroke. any experience with these?
Old Feb 18, 2006 | 09:33 AM
SStrokerAce's Avatar
The standard H beams should clear. At least they do in every other setup the cam is run in.
Bret
Old Feb 18, 2006 | 07:56 PM
96LT1TX's Avatar
hey bret, what about the 230/236 XE Comp cam? I dont know the base diameter... should I call comp and make sure its the .95" diameter? Does this even matter since the lift is so small?
Old Feb 18, 2006 | 08:09 PM
ssnorm96's Avatar
I've always heard it depends on what bolts are used in the rods....cap head bolts usually don't require any work.....just from what I understand.
Old Feb 18, 2006 | 09:03 PM
that base circle is larger than the LE cam.
RUENUF
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Don 97 SS
Jul 11, 2005 08:50 AM
