Clean Pro Mag rockers?
Old Dec 31, 2004 | 07:17 PM
Jeff95TA's Avatar
Are you supposed to clean the Comp Pro Magnum rockers in mineral spirits to remove any bearing grease like you do with the lifters?
Old Dec 31, 2004 | 07:24 PM
rskrause's Avatar
Moderator
Re: Clean Pro Mag rockers?
I think that's what the instructions said the last time I looked.
Rich
Old Jan 1, 2005 | 06:56 AM
Jeff95TA's Avatar
Rich
I was only able to find the instructions for the Magnums, which said to clean everything, but couldn't find anything on Pro Mags. And Comp is probably closed today.
Old Jan 1, 2005 | 08:28 AM
rskrause's Avatar
Moderator
They should be cleaned in solvent and then soaked in motor oil before installation.
Rich
Old Jan 1, 2005 | 08:33 AM
Fastbird93's Avatar
Rich
This is kind of on kind of off the subject, but what exactly is good to use to clean them?? Reason I ask is because I have a new set of lifters that will be going in eventually.
Old Jan 1, 2005 | 08:52 AM
Jeff95TA's Avatar
Mineral spirits.
Old Jan 1, 2005 | 08:59 AM
Fastbird93's Avatar
Originally Posted by Jeff95TA
Mineral spirits.
Sadly, mineral spirits does nothing for me. Is that just mineral water or what?
Old Jan 1, 2005 | 09:08 AM
Jeff95TA's Avatar
You'd find it by the lacquer thinner & paint thinner products, probably close to the paint aisle.
Old Jan 1, 2005 | 09:27 AM
Fastbird93's Avatar
Ah, that's what I needed. Thank you Sir, you're a gentleman and a scholar.
Old Jan 1, 2005 | 12:59 PM
stereomandan's Avatar
yea, it's basically paint thinner.
I'm glad I saw this post, because I forgot that I should clean my Pro Mags before install.
Going to buy some mineral spirits now....
Dan
KamikaZ28
May 28, 2015 12:45 AM
rje
Sep 9, 2002 12:35 PM
SABLT194
Aug 21, 2002 07:45 PM
SABLT194
Aug 3, 2002 09:33 AM
