Check out these LT1 Timing Sets
Old 07-17-2003, 01:04 PM
PoorMan's Avatar
Summit has these Cloyes chains for the LT1. There are three, but what's up with the different pitch sizes? Do any of these work with the stock waterpump?
CLO-9-3150 Original True timing set,Chevy 8mm pitch LT1,LT4,L99 1995-up $343.39
CLO-9-3151 Original True timing set,Chevy 1/2in pitch LT1,LT4,L99 1995-up $343.39
CLO-9-9100 Timing Set ``Heavy Duty`` SB Chevy ``LT-1`` $343.39
Jeff D.
PoorMan is offline
Old 07-17-2003, 01:15 PM
llafro's Avatar
I would guess that they do, since they say LT1/4. They are awfully expensive, though. I put a regular small block (non-LT1) timing chain on mine with an electric water pump. The chain cost me $70, and the pump was $135. So, it gives me a few hp for less money. I can't see doing it any other way.
People talk about how the electric WP isn't as durable. That may be. It's kind of like the days of belt-driven pumps. If you lose the belt, you are stuck just the same. I have a green light to show that the pump is working, and a red light that comes on if anything goes wrong, such as a blown fuse.
BRAD
llafro is offline
Old 07-17-2003, 01:22 PM
GREGG 97Z's Avatar
I've never seen those before but for $350 I would hope they work with the stock wp. I don't know why someone would buy one of those though when the LT4 ED is around $200. Anyway, I went with the $80 Cloyes double roller and a CSI pump, all together about $215.
Also, what's an "L99?" , I guess that was supposed to read L98.
GREGG 97Z is offline
Old 07-17-2003, 01:35 PM
Serial Thriller's Avatar
The L99 is a smaller displacement version of the LT1 and was available in the Caprice.
Serial Thriller is offline
Old 07-17-2003, 01:37 PM
treyZ28's Avatar
Location: looking for a flow bench so Brook and I can race
Originally posted by llafro
I
People talk about how the electric WP isn't as durable. That may be. It's kind of like the days of belt-driven pumps. If you lose the belt, you are stuck just the same. BRAD
thats a bit irrelivant, dont you think
treyZ28 is offline
Old 07-17-2003, 02:13 PM
PoorMan's Avatar
Anyone know what the pitch is all about?
Jeff D.
PoorMan is offline
llafro's Avatar
Well he asked about the WP drive. I was just anticipating the comments that always seem to come when you suggest the regular SBC chain and an electric WP.
Maybe I should run all my posts by you first to see if they are relevant?
llafro is offline
Old 07-17-2003, 04:17 PM
treyZ28's Avatar
Nonetheless, the loose belt/ mech waterpump failure vs electric waterpump failure dont really apply. Well concidering our water pumps are driven off the timing chain, i'm not particularly worrie about overheading if my chain slips off.
All i am saying is that the reasoning you provided for the reliablity of the electric vs mechanical belt driven dont apply to us.
I prefer gatorade to powerade
treyZ28 is offline
Old 07-17-2003, 04:58 PM
speedmiser's Avatar
You can go even cheaper using the double roller set from Combination Motorsports - if I remember correctly it was 58 or 59 dollars.
speedmiser is offline
Old 07-17-2003, 09:50 PM
PoorMan's Avatar
I had someone send me some pics of the CLO-9-3151. It's a true roller and will work with stock pump. It comes with a third, smaller tooth gear about the same diameter as the crank gear though. Any idea what that is for?? I am thinking crank sensor or something sense I have a 94 and am not familiar with 96-97 cars.
Still can't figure out what gear the pitch is referring too though.
Jeff D
PoorMan is offline
Old 07-17-2003, 11:20 PM
94formulabz's Avatar
BRAD
I understand you brad, and its a good point. In the rare case that you lose your WP you don't neccesarly ruin your motor. If you paying attention at all when you drive you'll feel the loss of power and see you temperature nearing overheating. All you gotta do is shut that puppy down and replace your waterpump. A lot of people are scared that they are automatically gonna seize their motor if it goes.
94formulabz is offline
Old 07-17-2003, 11:27 PM
96LT14u2Nv's Avatar
just grab a cloyes true double roller and be done with it. u will have to get a elec. H20 pump, but that just adds a few HP. mine is holding up great. dont know what is up with the pitch.
96LT14u2Nv is offline
parkers Z28
03-11-2016 08:14 PM
Queens94z28
12-20-2014 09:11 PM
Red97LT1
9
12-17-2014 06:13 PM
siguy
11-27-2014 10:07 AM
danielbmx
08-27-2002 11:11 PM
Quick Reply: Check out these LT1 Timing Sets
