Cheap Horsepower
Old Dec 7, 2005 | 07:49 PM
BAvila21's Avatar
Cheap Horsepower
Guys I need to know how to make horsepower for cheap. I alread bought a Air Foil, worked really good. took off .2 sec in the 1/4. If you know anything that would help I would really like it.
Old Dec 7, 2005 | 08:01 PM
buzz12586's Avatar
Re: Cheap Horsepower
Nitrous. Cheapest Horsepower there is.
Old Dec 7, 2005 | 08:05 PM
96ZCamaro's Avatar
Did it really take of .2 sec???? or did you take into fact that you might have gotten better at driving?
Old Dec 7, 2005 | 08:21 PM
UtOhCop's Avatar
A 150 shot will take over a second off of your ET. Do it. Don't be afraid.
Old Dec 8, 2005 | 12:14 AM
Critter's Avatar
exhaust cut out... 100 bucks installed and bought... you can change from hella loud to stock quite. look in summit or jegs. take it to a muffler shop and tell them to take the cat off and put the cut out where it was.
Old Dec 8, 2005 | 07:56 AM
2000GTP's Avatar
Free mods. are a good start... also, what other stuff have you done to the car besides the airfoil?
Old Dec 8, 2005 | 08:09 AM
n2ceptor's Avatar
What do you consider cheap?????? 5 dollars or 5000 dollars?????
Usually people start out with CAI and cat-back system.. Cost around 300-500 for both...
Then theres the camshaft change, etc......
Find out what horsepower goal you have and work to that goal......
Old Dec 8, 2005 | 08:32 AM
Mean Green's Avatar
don't kid yourself, those airfoils are crap. they look pretty when you take off the elbow and that's about it. they increaser maybe 2-5 hp, far from enough to actually change your ET's.
you need to be a bit more specific on how much you're actually willing to spend or how much power you're trying to make. I'd say do the free mods (free obviously), then delete the cat and have a cutout put in ($30-$50), get some sticky tires ($200). those things will probably drop your ET's the most.
Old Dec 8, 2005 | 09:48 AM
Z28WannaB's Avatar
Get some pacesetter and LE1 head/cam package. Or go with FI.
- Z28wannab
Old Dec 8, 2005 | 10:24 AM
http://www.ws6.com/mod-4.htm
Old Dec 8, 2005 | 12:04 PM
nfa's Avatar
nfa
The word "Nitrous" is pretty much synonymous with "Cheap HP". The bang for the buck cannot be beat. However, it ends up costing more than ppl think due to the all the accessories that must be purchased to have a safe system. Then you have to think of all the other things that will need to be upgraded to cope with it (i.e. clutches, rear ends, etc).
ya gotta pay to play!
Old Dec 8, 2005 | 12:13 PM
Critter's Avatar
hey everything counts... i got my air foil for 20 bucks from a friend
Old Dec 8, 2005 | 12:33 PM
Alvin@pcmforless.com's Avatar
Tuning helps.
Here locally i've been picking up cars more than a lt header + off road Y pipe picked them up.. Like this one.
The first run is stock, the second is when he came back with long tubes/off road Y and the last is the same night after tuning.
http://www.pcmforless.com/images/dyn.../PurserZ28.jpg
Old Dec 8, 2005 | 12:37 PM
teke184's Avatar
if you want cheap...
buy a 3" inlet K&N or similar cone filter, put it in place of the stock air box.
have a cutout installed under the rear seats before the axle
gut the cat(s)
throttle body bypass and 160 stat
Old Dec 8, 2005 | 05:14 PM
Jazsun's Avatar
160 stat does ****.
