Cheap, Good springs.. where?
Old Feb 26, 2008 | 06:36 PM
Ironxcross's Avatar
I'm looking for a set of decent valve springs, something better than stock that can handle 1.6 or 1.7 rockers easily without breaking the bank. Someone suggested LT4s, how good are they?
Old Feb 26, 2008 | 07:14 PM
truedualws6's Avatar
LT4s are your lowest cost option but only good to about .510" lift. I know the
hotcam has .525" lift and people run them, but I don't like a .035" safety margin to
coil bind. Another lower cost ($100) option is the Isky 235-D which is good to
.550" lift.
Old Feb 26, 2008 | 07:20 PM
dangalla's Avatar
the pac 1218 arent very much and they are a very good spring
MeanGreen97Z's Avatar
.550" lift.
Will the Isky run with the stock hardware or do they come with their own?
Old Feb 26, 2008 | 07:27 PM
I bought Iskys initially before I did the first spring swap back in 2003. I was told
that they are a direct replacement and they appeared to be just that. I did not
actually install them or mock them up. I changed plans and went with the Comp
26918s and sold the Iskys. Since the Iskys are a 1.26 OD spring they should
drop in place of a stocker. They have a damper, but it's about .900" ID which
should work with the stock hardware.
Old Feb 26, 2008 | 07:41 PM
mdenz3's Avatar
What camshaft will these be going with?
Old Feb 26, 2008 | 08:03 PM
Ironxcross's Avatar
Stock cam. 1.6 or 1.7 rockers.
Old Feb 26, 2008 | 08:07 PM
mdenz3's Avatar
LT4 springs are what most people use for 1.6 rockers on a stock cam. A set can be had new for about $40, but you may be able to get them cheaper in the classified section from someone who is upgrading the springs on their hotcam kit.
Old Feb 26, 2008 | 08:12 PM
I'll sell you my LT4 springs with less than 5k miles on them for 20$ plus shipping. 25$ shipped.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
kandied91z
Jan 23, 2015 11:14 AM
Snoman73
Nov 17, 2014 07:22 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
