Charging Problems
Old Apr 25, 2005 | 05:26 PM
  #31
95 firechicken's Avatar
Re: Charging Problems
i think i might have fixed the problem I installed the racetronix wiring harness for the fuel pump and now my dash gauge is almost 3/4 the only time it drops down now is when i'm in gear at a light with the head lights on and defogger running
Any body know a good idle RPM for a CC 305 cam i'm thinking 700-800 RPM ???
Old Apr 25, 2005 | 05:38 PM
  #32
RobbyRob's Avatar
Originally Posted by 95 firechicken
I've been having a charging problem in my car (95 formula) for 2 plus years now I've change every thing I can think of and it's still there so I bought a 200 amp alternator thinking that would fix the problem but no luck now when I'm at a light the volt gauge drops down to 9-10 volts PLEASE HELP I'm ready to shoot my dam car a put it out of it's misery
Dude I had the same problem for over 2 years myself. The Racetronix fuel pump and wire harness fix the problem. I tryed everything too. You can do a search and find my post on that.
It's been 6 months now a not a drop pass 12.2 volts. I wish I know that from the start cause I spent a lot of money trying to fix it.
Old Apr 25, 2005 | 05:46 PM
  #33
Talking Re: Charging Problems
i hope i have the same results as you
Old Apr 25, 2005 | 06:10 PM
  #34
st_paul's Avatar
did you guys get the whole system 135-FLT1-FPK2 or just the assembly 135-FLT1-FPA? or could i get the harness 135-FLT1-FPWHG-2 and get the pump from holley since it is cheaper.
Old Apr 25, 2005 | 06:11 PM
  #35
RobbyRob's Avatar
I'm sure you will. Man just reading your thread just made me sick.Mine drove me crazy for the longest time.. I know what you've gone through.
Now you'll be o.k.
Old Apr 25, 2005 | 06:14 PM
  #36
i just got the harness
Old Apr 25, 2005 | 06:34 PM
  #37
RobbyRob's Avatar
Well I got a good deal on the both. I think my pump was on the way out. The car ran better with just the pump done. I had run the wiring with the car on a lift a few days later... Now I know I'm getting enough fuel..
Old Apr 25, 2005 | 06:51 PM
  #38
Z95m6's Avatar
Just to let you guys in i installed a racetronix pump and wiring harness and i think it just masked my problems. Because when i'm at WOT the voltage to all my sensors start to drop. Have you guys monitored them? My TPS voltage drop down to 3.9 volts and falls to 80% throttle even though i still had the pedal to the floor. Also my pcm voltage is falling to at high rpms. I'm trying to locate my problem still.
Old Apr 25, 2005 | 07:21 PM
  #39
RobbyRob's Avatar
I would change the fuel pump too. Only when I did both it was 100%. I had voltage droppen every where.
Old Apr 25, 2005 | 07:24 PM
  #40
Z95m6's Avatar
If you are talking to me i did both of them. Have you actually monitored your sensor voltage under a load?
Old Apr 25, 2005 | 07:32 PM
  #41
RobbyRob's Avatar
Yeah. Everything cleared up once I did to racetronix kit. Did you reset your computer? Sometimes the computer will hold the code and keep acting f-ed up.
Old Apr 25, 2005 | 07:38 PM
  #42
Z95m6's Avatar
I'm not getting any codes, i've watched the voltage drop on datamaster. If you hook your car up to some sort of laptop/scanmaster i bet you will see a lot lower voltage at your pcm which can cause some problems. I may be wrong but i'd look into it.
Old Apr 26, 2005 | 10:03 PM
  #43
RobbyRob's Avatar
I have autoxray and datamaster. Like I said after I did the fuel pump and wire harness and reset the computer my voltage problems cleared up. Getting 12 volts now.
Old Apr 27, 2005 | 10:07 PM
  #44
wolfepack95's Avatar
sounds like you may have a different problem . But when i bought my Z last year the voltage would drop at idle. seemed to clear up at a higher RPM. I replaced the battery and Alt. after about two months it turned out the previous ower had put a smaller Pulley on the crank and it wouldnt spin the ALT fast enough at Idle. I switch it back to the larger one and been fine sence. Just thought i would share that..
Happy motoring.....
Old Apr 28, 2005 | 07:53 AM
  #45
RobbyRob's Avatar
I have a 35% under drive on my car. I just rised the idel 50 rpm. Keeps me at very worse of 12.3 volts @ avg. of 13.6 to 12.8.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97z28k&N
Jan 9, 2015 04:58 AM
