Charging Problems
Old Apr 18, 2005 | 04:43 PM
  #16
95 firechicken's Avatar
Re: Charging Problems
I changed the whole column/switch's a couple of months ago
Old Apr 18, 2005 | 08:41 PM
  #17
Robs97Z28's Avatar
You don't understand. The belt rides on top of the damper. If it is spinning the alt will never turn at the correct rpm and will never charge the battery.
Old Apr 18, 2005 | 08:53 PM
  #18
slopokrodrigez's Avatar
Originally Posted by Robs97Z28
paint a line cross the damper hub and then start the car run it for a few minites. If the line is still lined up damper is good.
Think he's got your problem down cold. Put the mark on the side of the hub where it meets the crank. Makes sense to me since when your idling higher, your voltage is higher. But, are you using a voltmeter or still relying on the gage in the dash?
Old Apr 18, 2005 | 09:23 PM
  #19
Robs97Z28's Avatar
this was the problen I had on mine. Damper looked fine, but I took the belt off I could turn the outside hub. It also make noise like the fan belt was slipping.
Old Apr 18, 2005 | 10:14 PM
  #20
just to clarify your talking about the Harmonic Balancer correct ?
If so and it is spinning with the belt of how to I clarify the problem ?
Rob I apologize I misunderstood you earlier
Old Apr 19, 2005 | 04:52 AM
  #21
Try tightening the bolt with loc-tite using an impact gun. Put your white mark on it again and go for a ride. If it slips again, you're gona have to remove the hub and see what the end of the crank shaft looks like.
The only thing that bothers me about this theory is it should be squeeling like a pig at a roast. But I did'nt see you mention anything about noise. Is it noisy?
Old Apr 19, 2005 | 07:36 AM
  #22
it sounds fine at idle and at high rpm i found that Thunder racing sells a keyed hub for the LT1 that might be the way to go if it is slipping i try it tonight and post my findings
Old Apr 19, 2005 | 04:39 PM
  #23
Robs97Z28's Avatar
yes, that is correct. Two ways: 1. remove the belt and see if you can move the outside ring by hand. 2. paint a straight line acroo the front of the damper. then either let the car idle for 10 mins or drive it around the block and see if the line you painted still lines up. You may want to rev it up a couple of times to be sure the damper isn't moving before you check if there wasn't any line movement.
Old Apr 19, 2005 | 07:20 PM
  #24
well that's not the problem , I can move the whole crank maybe an 1/8 of an inch , the hub/damper are tight on the crank any other ideas???
Old Apr 20, 2005 | 06:54 AM
  #25
ttt
Old Apr 21, 2005 | 06:51 AM
  #26
any ideas ????
Old Apr 22, 2005 | 05:15 AM
  #27
What is your engine speed at idle?
Old Apr 22, 2005 | 07:08 AM
  #28
800 in park and 700 in gear
Old Apr 22, 2005 | 08:47 PM
  #29
Have someone press the throttle to about 1000 and measure the battery voltage.
Old Apr 25, 2005 | 02:03 PM
  #30
st_paul's Avatar
this is a great post i am having the same problem. except my voltage starts at 14 volts then after running for a while it goes down to 10.6 volts. maybe bad damper or belt??
