Changing Plugs and Wires
Old Feb 7, 2004 | 07:59 AM
orrink's Avatar
Need a how to description of how to change plugs and wires plus any recommendations.
Old Feb 7, 2004 | 08:18 AM
Have you tried a search? I see this is your second post with the same question. Sorry no one has responded, but it is a matter of personal choice as to how to go about getting to the plugs and wires. What is easy for some is not easy for others. It depends on how skinny your arms are and such. Depending on how adept you are, it can be an ok job or a nightmare.
Old Feb 7, 2004 | 08:19 AM
94ZGRNMCHN's Avatar
If you dont have headers, buy some change plugs wires install the headers and your home free.Otherwise with stock manifolds good friggin luck, huge PITA.
Old Feb 7, 2004 | 08:36 AM
orrink's Avatar
I have Edelbrock headers. Looking at threads about OTVC setup. Does the loom screw in to the valve covers?
Old Feb 7, 2004 | 02:50 PM
My95Z's Avatar
yeah.. do the OTVC wires from thunderracing.com I have those.. they come with all teh criping and cutting tools, the brackets that do go into the top of teh valve cover. they protect the wires from the header heat and they look sweet too
Old Feb 7, 2004 | 03:59 PM
95BlackTA's Avatar
Yea get the OVC and throw them on there. If you need any help with the plugs, I also have Edlebrock shorties, so it would be pretty much the same for both of us(if you have shorties, then the same).
Make sure you have alot of tools before you start. Spark plug socket, various extensions, swivel attachment, wrench to go over sprak plug socket when you cant fit the socket wrench over it. I also bought this
http://www.slponline.com/view_produc...RTNUMBER=30102
because I couldnt get the number 6 plug out..it was on there too tight. Threw that sucker on there and put on my gearwrench and walah!
If you're having trouble with a certain plug, let me know and I can prolly help you.
Old Feb 7, 2004 | 05:55 PM
orrink's Avatar
Thanks - What about the wire install? Will I need to get under the car? Do you drill holes in the valve cover fot the OVC wire loom?
PCLZ28
Dec 24, 2015 05:19 PM
armedtrigger
Feb 24, 2015 08:30 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
IRABuss
Sep 7, 2011 09:08 PM
