Longtubes and transmission clearance
For all of you that have Hooker LT's: can the transmission be taken down to do a clutch w/o having to remove the headers? I sure do hope thats the case....thanks in advance.
all depends on your setup and what y-pipe you have... if memory erves me right, you will need to try and move the headers out of the way(which probably means out or loose enough to move around. I may be wrong but that is what I htink
