Changing the Opti
Old Sep 9, 2005 | 05:30 PM
Red96Lt1's Avatar
Changing the Opti
Where is a good "how to" on changing the opti? Thanks.
Old Sep 9, 2005 | 07:58 PM
Jameslt1TA's Avatar
Re: Changing the Opti
Im betting Shoebox's site has something on it...just do half of the cam install part.
www.shbox.com
Old Sep 12, 2005 | 10:08 AM
Red96Lt1's Avatar
ok, cool. I looked at his site, but didn't think to look in the cam install part, but it doesn't go into as much detail as I think I need. Do you have to remove the waterpump to remove the opti?
Old Sep 12, 2005 | 10:37 AM
Evil Eric's Avatar
Shoebox's site has a ton of technical stuff, but I dont think there is a write up specific write up on an optispark swap. I used his cam swap last year and it was to the tee , but it has alot of extra stuff you dont have to do to get the opti spark out. The only things you really have to do is:
* remove the intake piping
*unplug the coil from the opti
*Drain radiator, remove all hoses from the water pump
*remove the waterpump (some people like to remove the radiator for more clearance, this is not entirely nessicary)
*unplug electrical connection from opti
*3 screws hold th opti on, when you install the new one make sure the cam is indexed to the rotor on the back of the opti correctly.
Its not a very hard thing to do..I guess what im trying to say is once you do it you'll be able to do the whole thing again by memory.
Old Sep 12, 2005 | 10:39 AM
As you read the cam removal guide, one of the steps to get to the opti is to remove the water pump. You don't have to remove the fans unless you just want the room and you don't have to remove the radiator.
Just go the "~Disassembling the front of the engine~" section and use what you need from that. Not everything will apply. The crank pulley and the water pump are the things that are in the way of the opti coming out.
The site I used to refer people to for opti replacement is no longer there.
Old Sep 12, 2005 | 10:43 AM
Red96Lt1's Avatar
Thanks!
Old Sep 12, 2005 | 01:55 PM
1996z28m6's Avatar
dont forget the air pump removal also dont forget the water pump gaskets. on your first try its gonna be around 5 hrs or more but after youve done it 5 times it gets down to 2 hrs . and you also might want to remove the fans...not a hard thing to do but will save you time in the long run.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Sergio
Jan 27, 2016 04:27 PM
grabbem88
Mar 18, 2015 01:25 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
