Changing my thermostat to 160*
My car has been getting hot. Seems like the thremostat is sticking. So I was wondering if I change the thermostat to a 160* one will it cause any problems with anything?
Re: Changing my thermostat to 160*
I switched to a 160 stat and never had a problem. As far as I know this is pretty common among many LT1 owners and I've never heard of any negative side effects.
No, it'll be fine, but to get full benefit of it you'd want a pcm tune to go with it. I have my fans set for 180/190 with mine, and in mid summer traffic I've never seen it go over 195 at idle. In the cool weather its usually 165-170.
I almost feel it doesn't get quite warm enough to heat the oil properly during short trips. Though it is perfectly fine.
my car came with it already installed. never had any problems with heat in the cooler weather, i park the car for the winter. just keep in mind that the cooler the engine the more hp even if its stock.
This is my experience with the car in my signature. 160 thermostat installed. No reprogramming. Temp stays right at 180 all the time. Fans never kick on. Heat works great.
I'm pretty sure my thermostat is sticking closed cause the temp goes up to red line then quickly drops down half way to 210* I pulled my opti today so i'm going to put a 160* and see how the temp goes.
Jan 23, 2015 01:13 PM
