changing my opti
Old Jan 21, 2010 | 08:24 AM
  #16
96LT1TX's Avatar
It has been 2 years since I did it last, but if you take off the water pump cant you just pull the opti out and up without taking the pulley off too?
Not that it matters much...
I will be doing this though in a few weeks.
Old Jan 22, 2010 | 12:17 AM
  #17
RKPsk8er's Avatar
Originally Posted by Drew24
yeah your going to have to pull the harmonic balancer pulley off but it is really easy just go to an autozone and rent a harmonic balancer puller. You pay like 20 bucks and when you return it they give the 20 bucks back. The thing that helped me when pulling it i didn't use the bolts that the pulley puller came with i used the bolts that hold the balancer on. Good luck and bring lots of beer
i tried this today but the stock bolts wouldn't fit the assembly so i had to drill it out slightly and I still haven't been able to get the stupid thing off. any tips?
Old Jan 22, 2010 | 01:57 AM
  #18
RamAir95TA's Avatar
The pulley needs to come off as the opti needs to be pulled away from the timing cover. The pulley is blocking it.
Sounds like you have the wrong puller (it can be used but it's easier to use a 3-jaw puller).
Old Jan 22, 2010 | 02:35 AM
  #19
RKPsk8er's Avatar
Any ideas on how to make this one work as I can't return it now that its been modified? I got some longer bolts from lowes today that may work. also, i've read of a center, hub bolt that I was apparently unaware of. I think if I take it off, this puller may work.
Old Jan 22, 2010 | 05:23 AM
  #20
If you are taking the center bolt out of the hub, you are trying to pull the hub off. YOU DO NOT HAVE TO PULL THE HUB OFF THE CRANK TO CHANGE THE OPTI. You only need to pull the pulley/damper off the hub. Sounds like you are screwing the puller bolts into the threads on the hub arms, and pulling on it - WRONG WAY.
Courtesy of Shoebox:
http://shbox.com/1/pull_pulley.jpg
Old Jan 22, 2010 | 09:15 PM
  #21
RKPsk8er's Avatar
yes i realized i was accomplishing nothing and got the correct 3 claw puller. im all done with the opti replacement but i dont remember the orientation of the pulley to the hub and it has two weights on it and im not sure which way to put it. I noticed the hub has a nub on one side and the pulley has an arrow. anyone know if these are supposed to line up or am I screwed?
Old Jan 22, 2010 | 11:10 PM
  #22
The hub has three arms. They are not evenly spaced. The pulley will only bolt to it in one position.
Old Jan 22, 2010 | 11:54 PM
  #23
RKPsk8er's Avatar
I appreciate your knowledge. I actually measured the distance and realized it. Opti is on and running strong so fingers crossed.
Old Mar 13, 2011 | 10:09 PM
  #24
formula90's Avatar
Re: changing my opti
Your the man Fred.. nuff said...
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Sergio
Jan 27, 2016 04:27 PM
grabbem88
Mar 18, 2015 01:25 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
