Changing cams cc503
Old Apr 28, 2011 | 09:29 PM
Henson071's Avatar
Changing cams cc503
Hey guys, I have the hot cam kit in my 97 Z28. Im thinking about going with the cc503 cam. My question, will everything that came with the hotcam kit be able to support the cc503? I was hoping to be able to just swap cams since I already had upgraded springs and 1.6 rockers. THanks for your input.
Danny
Old Apr 28, 2011 | 10:15 PM
96capricemgr's Avatar
Re: Changing cams cc503
The rockers should handle it but the springs in the HOT kit are marginal for the HOT cam absolutely not up to the task of a more aggressive lobe on an aftermarket cam.
I have seen conflicting reports of how much lift the "LT4" kit rockers can handle .550-.575 you will be looking at .544 with that cam and the 1.6s so you would just do well to check rocker slot to stud/polylock clearance. Should be fine but should be checked.
Old May 4, 2011 | 07:30 AM
Ocala93TA's Avatar
I would definatley upgrade springs just my opinion
Old Jun 13, 2011 | 12:29 AM
camaro69z's Avatar
Definately. Lloyd Elliot sells a set of springs for $130 shipped that I used, heard good things from others about them too.
parkers Z28
Mar 11, 2016 08:14 PM
nikolt1
Feb 27, 2015 09:10 PM
camy 1993
Feb 1, 2015 07:16 PM
InfernalVortex
Jan 17, 2015 09:35 AM
