LT1 won't start (no juice when u turn the key)
Old Jun 6, 2011 | 09:25 AM
BrianwZ28's Avatar
i have a 95 Z28 and it willnt turn over. you can turn the key and no gauages light up, the ony thing that comes on is the radio but no sound from the speakers. it die on me going down the road. it started iding rough then just cut off. anyone have any ideas what it could be?
Old Jun 6, 2011 | 11:46 AM
grabbem88's Avatar
Re: LT1 won't start (no juice when u turn the key)
First you need to verify battery is charged and will hold charge
Then if battery checks out test alternator. Also check your power block if everything tight
And not corroded
Start there first.
Old Jun 6, 2011 | 11:53 AM
GRIDERMAN87's Avatar
hook jumpers up to it and see if you get power, then if you can get it to start and run pull the hot battery cable, if the car then dies its a bad alternator
Old Jun 6, 2011 | 11:59 AM
It could be ignition switch related.
http://shbox.com/ignsw/ign_switch_repl.html
Old Jun 6, 2011 | 12:02 PM
grabbem88's Avatar
Ouch! Don't ever pull the hot wire off the alternator while running
I know its an "old school" way to check if alternator but it is a big no no
Easiest way is to test it with a multi meter. While running probe the battery if you get 13- 13.8 volts then
Alternator is working. I have seen some charge a little lower but not less than 12.5 volts
Old Jun 6, 2011 | 12:05 PM
not off the alt., off the battery it does the same trick without the shocking side effect, shoebox could be correct as well, also could be vats see if your security light is blinking as well
Old Jun 6, 2011 | 12:09 PM
grabbem88's Avatar
That was the next area but I'm slow lol
Btw on that topic have you ever seen a car have dead spot in the ignition cause
Of this? Reason I ask is I have to wait a few seconds or when alt gauge goes up else
Its dead if I just put key in and immediately turn it. Just wondered
Old Jun 6, 2011 | 02:02 PM
The switch has sliding contacts, so anything is possible if it gets worn out.
Old Jun 6, 2011 | 04:42 PM
grabbem88's Avatar
Ok thanks. I was thinking key chip
Old Jun 7, 2011 | 08:21 AM
BrianwZ28's Avatar
thanks for all the input. i guess im going to have to try the ignition switch, evetything else checks out. im going to go over everything once again then dive head first into the ignition switch. thanks for all the help!!
Old Jun 13, 2011 | 09:47 AM
BrianwZ28's Avatar
She is alive!! thanks shoebox for that link. as soon as i changed out that switch she fired right up!
liamcg97
Nov 25, 2019 05:55 PM
Jessie4tin
Jan 7, 2015 08:53 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
