Cerious as to did my heads flow decent? numbers inside
Old May 13, 2005 | 03:20 PM
LittleRedZ's Avatar
Ok these are 190cc AFR heads
2.02/160 valves
Ported By hand with a 5 angle valve job, but not a comp. Port job
It says they were flowed with an AIR HORN ???? dont know what that is
but heres the numbers
Intake Exhaust
98.5@100 107
157.9@200 147
211.6@300 189.9
255.8@400 210.3
274.8@500 223.8
284.2@600 237.4
293.7@700
Any thoughts or comments would be apriciated
Old May 13, 2005 | 03:41 PM
Birdie2000's Avatar
Re: Cerious as to did my heads flow decent? numbers inside
Those are badass #'s for 190cc!
Dunno what an air horn is, but I'd assume it's like flowing with a pipe. Those are very good exhaust numbers as well.
I sold a well ported set of 190cc AFR's (came out to 193cc when done. The intake cfm was a bit less, but the exhaust is inline with what mine woulda been when flowed with a pipe. Mine were more of a street port though, as there was still some room left on the intake since the exhaust is somewhat more important in a blower app. Either way, your low lift #'s are great. Who did your porting?
Old May 13, 2005 | 03:49 PM
LittleRedZ's Avatar
Thank for the comments the car runs great just was cerious on to what they flowed like compared to lt4 heads or stock lt1 ported. My heads are as well have more room left on them to port, as i said it wasnt a comp port job just a basic hand port/5 angle valve job.
Belive it or not just a local guy here in maryland has done a good amount of lt1 work and is a 1 man shop. Advanced Valve in Hyatstown maryland.
i'm looking into going turbo next year and getting rid of the heads most likely will go with 215 raised afrs and Accel(victor junior style intake manifold) that should do just fine
Old May 13, 2005 | 04:20 PM
Birdie2000's Avatar
Same with the guy who did my old ones. I bet a lot of people would be blown away if they found out how many lesser-known porters are out there who can produce outstanding work.
Old May 14, 2005 | 08:38 PM
LittleRedZ's Avatar
ttt
DirtyDaveW
Dec 1, 2016 05:37 PM
parkers Z28
Mar 11, 2016 08:14 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
