cc503 cam help
Old Mar 9, 2009 | 05:07 PM
budgetlt1's Avatar
cc503 cam help
hey i'm new to this forum. my question is this: i have a cc503 cam and before i install it, what spring would be a good but cheap alternative to the stock lt1 valve springs. i am going to stay with stock 1.5 rockers.
Old Mar 9, 2009 | 05:36 PM
budgetlt1's Avatar
that is, unless the stock rockers will not work...
Old Mar 9, 2009 | 05:53 PM
4thgencamarofan's Avatar
I would say you might as well upgrade to cc promagnum 1.6RR's while you rippin everything apart. Not sure if you would need new springs or not though.
Old Mar 9, 2009 | 07:30 PM
budgetlt1's Avatar
i'm afraid i wont pass ca emissions w/1.6's either way i can add those after smog test. just not sure if the stock springs will handle the lift
Old Mar 9, 2009 | 07:34 PM
chevyowner02's Avatar
http://store.summitracing.com/egnsea...alse&N=700+115
Works good and no machine work needed to fit.
parkers Z28
Mar 11, 2016 08:14 PM
nikolt1
Feb 27, 2015 09:10 PM
camy 1993
Feb 1, 2015 07:16 PM
InfernalVortex
Jan 17, 2015 09:35 AM
