cc306 cam
Old Dec 10, 2011 | 12:40 PM
1eez28's Avatar
cc306 cam
hey everybody im going to put the cc306 in my lt1 and i have stock gears but im going to put 4.10s in so my question is would it be ok if i drive my car around with stock gears for awhile?
Old Dec 10, 2011 | 02:18 PM
bencher's Avatar
Re: cc306 cam
I'll help ya out here, redo this thread in the proper sub catagory. Podcast section wont get you much help.
Old Dec 10, 2011 | 06:56 PM
Ocala93TA's Avatar
Re: cc306 cam
Stock gears wont be the problem but not having it tuned for the cam can be a bigger issue , If i was you i would change everything you can and get a tune to match cam gears etc.
Old Dec 10, 2011 | 07:40 PM
TeeTopZ's Avatar
Re: cc306 cam
Definitely need a tune, that cam is pretty big unless you have headwork done
Old Dec 11, 2011 | 11:05 AM
RamAir95TA's Avatar
Re: cc306 cam
That cam in a DD on stock heads is an overall mistake, much less that cam on a DD with stock heads and stock gears. Maybe try a search on what works and what doesn't.
Old Dec 11, 2011 | 11:23 AM
1eez28's Avatar
Re: cc306 cam
no im doin head work too, and im totally getting a tune also. i also heard that i could also have a vacuum problem also?
Old Dec 21, 2011 | 03:42 AM
Bersaglieri's Avatar
Re: cc306 cam
I didn't mind my CC306 when I had one, but I didn't really daily drive the car. I had 3.73's at first, then 4.11's. Knowing what I know now I'd pick a different camshaft for a daily driver. Street/strip do whatever you want, but daily driver I'd look else where with or without head work.
On that note I never had a vacuum issue with the CC306.
-Dustin-
Old Dec 25, 2011 | 02:26 PM
neil350's Avatar
Re: cc306 cam
I have 3.42s in my 12 Bolt because thats what it came with, switching to 3.90s though. Driven the car like this for a while, it drives fine, very well mannered on the highway. Be interesting to see the difference the gears make since I haven't driven it yet with 3.90s. Far as driving the car untuned with a CC306? Drove the car pretty much untuned after the EFI 24X, just the base line changes and a make it idle tune, nite mare and a half. Car drove like garbage. It still needs a little more driviability tuning, but it actually does drive nice with the tune. CC306 isn't a bad cam, but I am sure on my set up I gave up power using it over a custom cam.
rideordie
Nov 5, 2019 04:52 PM
mightymouse383
Jul 20, 2016 07:34 AM
StansZ28
Feb 19, 2015 07:39 AM
Queens94z28
Nov 20, 2014 06:03 PM
