Cc306
Old Jun 6, 2009 | 01:20 PM
Diamhea's Avatar
Cc306
About to buy it for my LT1 w/ 112k on the clock. Could somebody link me to the valve springs that are recommended for this swap?
Old Jun 6, 2009 | 01:46 PM
orange94z28's Avatar
cc306
summit suggested part number CCA-986-16 for this cam. I had them on mine and never had a problem.
Old Jun 6, 2009 | 03:49 PM
Airbornec507's Avatar
I used to run the 986 springs with my CC306 cam and didn't realy think they controled the valve that well. I use the PAC 1218 springs now and have much better valve control (installed at 1.775"). My MAP also shows no sign of valve float as it did with the 986 springs. Another good spring set up to go with if you can't foot the bill for the 1218 springs is the Patriot Gold Exteme spring set. I don't have personal experiance with those but they should work as well.
Old Jun 6, 2009 | 04:30 PM
Diamhea's Avatar
Summit says these are required for installation of new springs:
http://store.summitracing.com/partde...art=CCA-740-16
True? If so I'm copping that set too.
Old Jun 6, 2009 | 05:24 PM
Check this out: http://www.thunderracing.com/catalog...&sid=815#P6732
Comes with everything you'll need. Get the "Gold Extreme" set for $275.
Old Jun 6, 2009 | 05:57 PM
Diamhea's Avatar
Great. I'll get that set. Thanks.
Old Jun 8, 2009 | 11:21 AM
Diamhea's Avatar
Am I going to need to grind that freaking dowel pin down on the cc306?
Old Jun 8, 2009 | 11:33 AM
i bought mine new from summit for my 94 and i didnt have to.
Old Jun 8, 2009 | 10:35 PM
twcblackhand6970's Avatar
I got mine through comp and they made them with the long dowel pin so noone had to "buy a new pin" but could just grind it down is what I was told.
Old Jun 9, 2009 | 09:43 PM
Diamhea's Avatar
...and it has the longer dowel pin!
Does the pin need to be tampered with at all if I have the unvented opti? Shoebox's site seems to allude that it doesn't.
Old Jun 10, 2009 | 12:37 AM
if you have the unvented setup, the dowel pin is shorter than the ones for the vented. so yes, you will have to tamper with it.
Old Jun 10, 2009 | 09:11 AM
Bersaglieri's Avatar
Too bad I didnt see this earlier I'm probably selling my whole CC306 camshaft/springs, pushrods, setup. Still got the reciept to yours?
-Dustin-
Old Jun 10, 2009 | 07:11 PM
PWR SHFT's Avatar
-Dustin-
I might be interested. Send me a PM with the price and details.
Old Jun 11, 2009 | 12:42 AM
Keep an eye on the for sale section in a week or two. That or I'll keep it and run it, it's a good cam to spite what nay sayers want you to think. It's been in the 9's at least once.
-Dustin-
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
