cc305 or hotcam w/383?
Old Apr 28, 2004 | 01:16 PM
  #46
Briank8811's Avatar
If it were up to me i would put some street radials on but my old man is "strongly encouraging" me to put on street tires. If the car only runs mid 13's then it will be ok. So far he hasnt steered me in the wrong direction.
P.S. Will it really only run mid 13's in FL (LOL)
Old Apr 28, 2004 | 02:07 PM
  #47
Naegash's Avatar
Wow, expecting mid 13's out of a stroker... Don't ever become an investment banker, ok? I mean I know your dad has a lot of say and influence about what you do with your car, but that just doesn't seem like much return for your money.
Old Apr 28, 2004 | 02:37 PM
  #48
Guerardsgt's Avatar
Well I didn't bother to read all of the post in this topic but this is what I have.
I have a fully forged 383 and I'm running the cc305. I bought mine through thunder racing with a custom grind to make it a 112lsa not a 114lsa. I'm pretty impressed with the cam seeing how I put down 400rwhp with it and torque numbers to match. The cam is still pretty radical not as much as it could be but good enough for a good drive on the streets. I bought mine because it's a decent all around cam, at the time of purchase I was going to strap a 12pnd huffer to it. good luck on your selection and there are a lot of great cam selections people posted in this thread.
Old Apr 28, 2004 | 07:43 PM
  #49
Briank8811's Avatar
Shouldnt I only expect mid 13's if im running 375rwhp and 400rwtq with stock driveline where only the clutch has been replaced with a stock unit and im running BFGoodrich g-force t/a KDW p245's out back? Im in florida and the track is generally sticky and im also at sea level.
Old Apr 29, 2004 | 08:12 AM
  #50
WS Sick's Avatar
in my 93 I only dynoed in the 350 rwhp range and I ran several 12.3s @ 112 mph. (in Oklahoma)
Tires make a big difference , commuter tires on a race car at the track are like flipflops on a pro tennis player.
Old Apr 29, 2004 | 09:48 AM
  #51
gb95zconv's Avatar
At sea level I belive you will be very low 13s or high 12s on street tires(2.2 60'). I dont belive your cluth will be an issue on street tires .....with drag radials it may be after several passes.
Old Apr 29, 2004 | 10:44 AM
  #52
Deenasty's Avatar
i had a hotcam in my 383, with AFR heads. UNTUNED, the car dynoed 383rwhp, with 408.3 lbtq. The motor is a 10.5:1 comp motor. Made good power, excellent driveability. All around great cam. Now switched to a 240/240 595 595 112
Old Apr 29, 2004 | 11:14 AM
  #53
WS Sick's Avatar
And doesnt the bigger cam make you wonder why you used the hotcam?
Old Apr 29, 2004 | 11:49 AM
  #54
Deenasty's Avatar
well it wasnt my choice to go with the hotcam. I bought the motor from a friend, and the hotcam was already in it...But now that I have this cam, I love it!
Old Apr 29, 2004 | 04:09 PM
  #55
David94TA's Avatar
Have you dynoed it after the cam swap?
Old Apr 29, 2004 | 04:23 PM
  #56
Deenasty's Avatar
not yet, getting little bugs worked out so far...Have to do plugs, seal a small exhaust leak, replace o2's and then get tuned..once i do, i will post up new results...
Old May 1, 2004 | 11:35 AM
  #57
Briank8811's Avatar
Now u guys got me wanting a bigger cam before i even get to drive my car.....Bastards...LOL.
HarleyZ28
Oct 5, 2015 06:23 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Russ95Z28
Apr 23, 2015 01:55 PM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
