cc305 or hotcam w/383?
No kidding, I will tell you now, if you go with one of those cams because you want driveabilty or something like that , you will be kicking yourself the first time a turboed import blows your doors off on the top end.
Either of those cams in a 383 is like a stock cam in a 350. so go bigger at least 230+ duration@ 50 and 560+lift and you won't regret it. Remember that the more cubes you have the more cam you can get away with and be streetable. I am running a 230-240@50 cam in my 350 Lt1.
While I do agree that bigger cam is better with a 383, it really depends on how well the heads flow to get the most out out a bigger cam. If you plan to do some good flowing heads too...go bigger.
I can tell you I ran 12.5x @ 112 with a cc305 and stock mildly ported and matched heads with shorty headers, stock cat, and stock wieght... if that helps you any. Not super numbers for a 383 but respectable for that particular setup which passed emissions easily and drove like stock. Between those 2 cams do the cc305.
Other than the fact that im 16 and am going to be paying for gas and have a expensive girlfriend I would love to get a bigger cam. BTW my heads have a 5-angle valve job and the ports are smoothed. I already have a rocketship for a 16 year old and i still need to have SOME gas mileage. Dosnt a bigger cam than say a cc306 take a substantial ammount of vaccum?Thanks, Brian Kaiser
Originally posted by Dave88LX
And get rid of the expensive girlfriend. You don't need that **** when you're 16. Tell her if she wants to play spoiled princess to hit daddy up for some money.
Aaron
Frank
Originally posted by 12SCNDZ
I'm not sure about that one...My "little" CC305 with a stock bottom end LT1 runs 12.0 @ 112 MPH.
Frank
Frank
(but your car does run good)
i had the CC305 in my 93 T/A and my best off the bottle was a 12.3 @ 112, I had homeported heads, 3000 stall, 3.73 rear gear, and full exhaust (hooker Lts etc)
The cam ran nicely and I liked it so I put a simular cam in my 383 (in my 97)to start with (XE 224/230) the car had plenty of torque, and until I raced a respectable car I thought it was head and shoulders above my 93. I would allways get a good lead then lose it aftewards, if we had been racing 1/8 mile I probably would have nevr lost, but after that it felt like it was freewheeling as the LS1s and such came by me. Changing cams took car of that.
