CC 306 Switch
Old Apr 27, 2004 | 04:06 PM
  #16
z28poweredlt1's Avatar
Originally posted by Wildwill2855
I meant i heard when just cruising around you will have cam surge, well in drive your in higher rpms so your flowing more air and better velocity right? Wouldnt that help out the surging along with tuning by madwolf?
Cam suging is mainly when the car is at idle. Car would have kind of a rough idle, dont know the LSA on the cc306, But tuning is goind to make the car run awesome accros the whole RPM range.
Old Apr 27, 2004 | 04:18 PM
  #17
Wildwill2855's Avatar
I read when I get my PC programed to either get higher idle from 600 or so to about 900 if not I could always put the car in N at lights or something?
Old Apr 27, 2004 | 10:21 PM
  #18
other ideas?
Old Apr 28, 2004 | 09:53 AM
  #19
grygst76's Avatar
I have the 306 in my camaro and it definitely needs a tune for it to run even remotely right. I have no cam surge under 2000 like most people complain of and it ran like crap before the tune. If you plan on it and have an auto, be prepared to stay in first or second gear because it needs 3.42 or higher gears and a stall of minimum 2800. Rule of thumb is powerband of cam go 500 RPM higher with the convertor. Brian did my tune pcmforless and it was dead on the money.
Old Apr 28, 2004 | 01:56 PM
  #20
Grygrst did you notice a differnce right away when you put the cam in, So anything after first or second isnt good then?
Old Apr 28, 2004 | 02:46 PM
  #21
grygst76's Avatar
it's definitely noticeable The idle is rough; it had no power under 2000 until after the tune; and it ran real rich. I had bad cam surge and the whole motor shook, get the tune while your putting the cam in so there will be less downtime afterwards.
Old Apr 28, 2004 | 05:13 PM
  #22
How did it perform when you mashed on it, was it like its ok or was it a big change, and does it like surge when you mash it below 2k? or just when cruising!
Old Apr 28, 2004 | 05:21 PM
  #23
grygst76's Avatar
It was crap before the tune...felt like it was slowly reaching rpms in second and up but first gear was ok I also have ported big valve heads which made it doggish as well
Old Apr 28, 2004 | 05:28 PM
  #24
But your tune took care of that right?
Old Apr 28, 2004 | 10:13 PM
  #25
grygst76's Avatar
Old Apr 28, 2004 | 10:21 PM
  #26
I hope this pans out alright for me, wouldnt it make a differnce driving around town in D instead of OD because it will keep you in a higher rpm?
Old Apr 29, 2004 | 07:19 AM
  #27
grygst76's Avatar
Trust me, If you have an auto you will need to drive around town in 2!!! you will need gears of 3.42 or higher in order to really take advantage of that grind. You can get away with driving around in D though but why bother?? Do it right the first time and you will get more out of the new combination.
IndyZman
Oct 22, 2015 02:17 PM
truecontr3
Oct 11, 2015 09:30 AM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
