is this a cause for alarm??
Old Jul 20, 2006 | 05:53 PM
nodnarb481's Avatar
I got my subframe connectors installed yesterday. He said he had to disconnect the fuel lines to install it. I went under the car today and noticed this..
few questions..
1. What fuel line is this?
2. is it hurting my gas mileage?
3. Its best i just plug that back together right? it doesnt seem to reach very well but i think with a clamp there itll hold nicely.
4. should i be pissed? on a scale from 1-10.
thank you all
Old Jul 20, 2006 | 06:43 PM
LenT1's Avatar
Re: is this a cause for alarm??
I want to know the answer too!
Old Jul 20, 2006 | 06:49 PM
speed_demon24's Avatar
That line vents the fumes from the gas tank into the intake manifold, just connect it back up.
Old Jul 20, 2006 | 08:11 PM
Dave89IROC's Avatar
if needed, put a longer piece of hose on there, it holds no pressure
Old Jul 20, 2006 | 08:20 PM
LenT1's Avatar
That is still pretty careless of the mechanic!
Old Jul 20, 2006 | 09:00 PM
matLT1's Avatar
I'd be quite pissed myself, things like these are why I never let anyone else work on my car. As said above just reconnect and call it a day. However, judging by the fact that the dumb--s mechanic couldn't even reconnect that line I'd recommend inspecting anything else s/he could have screwed up.
Old Jul 20, 2006 | 09:05 PM
nodnarb481's Avatar
thats wut blows my mind. this is alex exhaust.. the dudes been in magazines and has a bigger reputation then anyone in my area.
Old Jul 20, 2006 | 09:18 PM
LT1_383's Avatar
He probably connected it, but it fell off because it looks like the SFCs are pushing up on the lines. Dosn't look like there was ever a clamp on the plastic line side.
Old Jul 20, 2006 | 10:30 PM
At least he had the sense to disconnect the lines and not burn your car down. Glad you found the loose hose, but it's not that big of a deal.
Old Jul 20, 2006 | 11:16 PM
nodnarb481's Avatar
thank you.. im getting better at finding and recognizing these things.. now if everyone could kindly direct their attention to my stripped bolt thread further down i could REALLY use help there...
http://web.camaross.com/forums/showthread.php?t=462157
Old Jul 21, 2006 | 07:06 AM
There is no clamp in that location on the factory lines.
Old Jul 21, 2006 | 08:45 AM
01Z's Avatar
01Z
It's not a big deal. I pulled my lines apart and moved them on top of the brake lines to get them out of the way for the weld up of the SFCs too. The evap line pulled out of the sleeve all by itself. I have since moved the lines back to their original position and the line has stayed put. Some of the cheesy things I find from the factory are amazing. This is one of them. Don't blame the mechanic or fabricator; its a design flaw imho.
Old Jul 21, 2006 | 01:16 PM
nodnarb481's Avatar
yea i can put it back in but it just comes back out so im gonna pull the little sleeve off the metal line a bit and get another clamp on the other side
Heathen1
Jan 2, 2016 04:27 PM
IndyZman
Oct 22, 2015 02:17 PM
MichiganSkip
Aug 6, 2015 09:38 AM
OutlawPerforman
Jun 15, 2015 12:49 AM
