carbureted lt1 help please
Old May 17, 2012 | 07:00 PM
David Henderson's Avatar
im putting a carbed lt1 in my camaro and was wondering will i have any use at all for the chassis harness
and i have heard of ppl putting a reverse cam distributor in i dnt understand is that where u put the dist, in the back of the engine?
Old May 18, 2012 | 10:19 AM
Re: carbureted lt1 help please
What year is the Camaro you are going to put the LT1 into?
You use a conventional SBC distributor. The LT1 intake manifold can be drilled to accept it, at the back. Then the manifold needs a shim to get the distributor to the correct height.
At this point, what you are putting it in becomes important, because the 4th Gens have an issue with the distributor and the cowl, while earlier models may not. Then there's the issue of what year/model chassis harness you are interfacing with.
Old May 18, 2012 | 07:04 PM
daddyoisback's Avatar
Fos Sale content deleted
Last edited by Injuneer; May 18, 2012 at 11:12 PM. Reason: Do not post parts for sale in the Tech forums. Use a PM.
Old May 18, 2012 | 08:55 PM
im putting it in a 2000 it will fit im going to use a low profile distributor
there is an lt1 carb intake manifold on summit im ordering
but i cant seem to find a distributor bc all of the ones ive looked a needed a computer
Old May 18, 2012 | 10:13 PM
96capricemgr's Avatar
The GMPP carbed intake is not a real performance piece. Far as I know it is made by Edelbrock and I would compare it to their entry level "performer" intakes for the gen 1 engine. This is a low rpm dual plane intake likely to increase torque and reduce hp compared to the stock LT1 injection manifold.
Far as a distributor even with low profile I bet you have to pull the intake and distributor at the same time to pull the distributor unless you cut on the car. Far as what would work without a computer you just need something equivalent to an old HEI. There are millions probably even 10s of millions of gen 1 SBC engines out there without a computer.
Old May 19, 2012 | 04:17 PM
thanks i know its going to be tight fit for the distributor i was planing on makeing it fit and thanks for the advice
Old May 20, 2012 | 10:12 PM
numskull's Avatar
I was thinking of doing the same thing. Where did you find the intake? Do ya have a link?
Old May 20, 2012 | 10:22 PM
GM Performance 24502592 - GM Performance Carbureted LT1 Intake Manifolds - Overview - SummitRacing.com
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
kennyirocz
3rd Gen / L98 Engine Tech
Feb 7, 2015 11:41 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
