Car wont start, weird electrical problems (video inside)
Old Apr 10, 2010 | 03:34 PM
Mikes 1994 z28's Avatar
When I parked my car two weeks ago it ran fine. I've check all the connections on the engine and nothing is unplugged. None of the fuses are blown either. I'm really lost as to were to start with this. The check engine light was not on when I parked it and I don't think I can even scan it now that it wont start.
Here is a video of what it's doing. As you can hear the fuel pump comes on and then the lights start flash on and off and things start clicking. I sounds like a starter solenoid clicking. I think something is shorting out possibly but again no fuses have blown. I don't even know where to begin.
Old Apr 11, 2010 | 02:01 AM
ram57ta's Avatar
Have you tried to charge the battery? Im pretty sure that was the starter solenoid clicking which would make me think the battery is defective.
Old Apr 11, 2010 | 02:21 AM
94CamaroZ28/SSClone's Avatar
Yea sounds like the battery.
Old Apr 11, 2010 | 10:04 AM
Look at the volt meter while you're trying to start it. The needle is buried in the red at the bottom of the gauge.
Old Apr 11, 2010 | 10:08 AM
craby's Avatar
multiple clicking like that indicates a dead battery, if it clicks only once then its more likely to be the starter, not always though. clean your battery terminals and cable ends with a wire brush and see if that helps. could also try cleaning the wire ends in the power junction box on the passenger side wheelwell. (red plastic box) u either have a bad battery or its not getting a good connection.
Old Apr 11, 2010 | 10:27 AM
Thanks guys I have the charger on it right now and im going to see what happens. I hope its just a semi half dead battery. I'll update you in a little bit.
Old Apr 11, 2010 | 12:47 PM
Charging the battery worked! haha. Everything back to normal. Thanks guys!
Old Apr 11, 2010 | 02:17 PM
craby's Avatar
now uve fixed the symptom move on the finding the issue. why did the battery go dead? door left open, hatch left open, battery shot, alternator failing, bad wire or connection?
jj71787
Dec 30, 2014 02:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
