Car won't start, PCM Dead??
Old Sep 2, 2004 | 11:56 PM
2Fast94TA's Avatar
ok tonight was my first night datalogging with Freescan and my mastach cable. I did three runs at the track over a 3 hour time span... (track is packed) and i left the cable plugged in laptop on and Freescan running inbetween runs. when leaving the track i turned the laptop off but left it pluged in the ALDL. i stopped for gas and when i got back on the interstate my Parking brake, ABS Inop, and LOW TRACTION light came on and went off. i suspected the mastach cable so i reached down and pulled the connectors out. i stopped at my friends house and stayed for a hour or so... when i went to leave my car would not turn over. all the dash lights came up but the fuel pump didnt start. on the second try i noticed smoke on the pass. side coming from under the hood. i ran out to smell something like superglue from my PCM area. the PCM was HOT to the touch. i called my friend up and he let my try the PCM in his 94 camaro auto ( mine is the same year auto but a T/A) and that also didnt work. i reset the fuses in the fuse box. and no help either. I really........... hate wiring gremlins
Old Sep 3, 2004 | 04:08 PM
2Fast94TA's Avatar
Re: Car won't start, PCM Dead??
can anybody help???
Old Sep 3, 2004 | 08:34 PM
JDBlaze85's Avatar
get a wiring diagram for you PCM and check every ground and power circuit going to the PCM harness.
Old Sep 3, 2004 | 11:21 PM
2Fast94TA's Avatar
so i should unplug all the PCM connectors and turn the key on and use the ground to check all the other pins?? also is a 94 pretty much the same as a 95?
Old Sep 3, 2004 | 11:26 PM
JDBlaze85's Avatar
yes, unplug them all, turn the key on, and check for 10.5+ volts on every power circuit with a voltmeter and to check the ground circuits......use a ohmmeter, set it to 200 ohms, and put the negative terminal lead to battery ground and with the other lead, probe each ground circuit. they must show 5.0 ohms or less.
94 is pretty much the same ( it may be exactly the same) but dont qoute me. get a 94 wiring diagram to be on the safe side.
Old Sep 3, 2004 | 11:29 PM
2Fast94TA's Avatar
is it possible my mastach cable caused this?? i did pull the cable leads out when driving down the road maybe that shorted the circuit in the PCM, i still dont understand why a new working PCM doesnt work
Old Sep 3, 2004 | 11:33 PM
JDBlaze85's Avatar
i doubt it. with your pcm hooked up, have you tried scanning it? does it communicate with your scan tool? If it doesnt communicate with your PCM or a known good PCM, then more likely you have an open power or ground circuit to the PCM. Or an open ALDL data circuit.
Old Sep 4, 2004 | 03:09 PM
2Fast94TA's Avatar
well all the PCM wiring seems to be fine, so now i believe it is a fried starter...
Britbilly
Jan 7, 2015 08:49 PM
Ricardo
Nov 29, 2014 10:58 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
