car won't start need help looking for shoebox input please help
Old May 6, 2004 | 02:09 PM
threadedtire's Avatar
ok, about a week ago i was driving on the high way and the car started breaking up really bad! so i got off the high way and it seemed to clear right up and everytime i go on the high way it seems to break up. but anyways now the only starts every once in awhile and now its to the point were it won't start at all. (it started yesterday a few times but only ran for about 2-3 minutes)
any help would be great. this is my everyday driver. i need this running asap (now)
thank you guys
Old May 6, 2004 | 02:11 PM
sorry the car is a obd2 1996 camaro z28 mods are 400 turbo 383 ........also i checked for fuel pressure and its fine there is no spark to the plug wires thank you
Old May 6, 2004 | 04:01 PM
Pullngz's Avatar
Got spark at the coil?
Old May 6, 2004 | 06:42 PM
ok i got the car running.....it was the ignition fuse it was loose not blown but anyways the car is now breaking up at high RPM and low rpm but only somtimes i dunno what do you guys think it could be???? i am thinking opti
Old May 6, 2004 | 08:03 PM
ZDriver96's Avatar
U need to check two things-
ignition and fuel
Check fuel first- Hook a fuel pressure gauge up to the valve on your fuel rail. THe valve is behind your intake manifold facing towards the drivers side at an angle.
If u have 36-40psi and its still breaking up its not your fuel.
CHeck your plugs and wires next
then if those check out its your opti... very likely anyways
Britbilly
Jan 7, 2015 08:49 PM
ro2207
Dec 4, 2014 06:18 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
