car won't start need help looking for shoebox input please help
ok, about a week ago i was driving on the high way and the car started breaking up really bad! so i got off the high way and it seemed to clear right up and everytime i go on the high way it seems to break up. but anyways now the only starts every once in awhile and now its to the point were it won't start at all. (it started yesterday a few times but only ran for about 2-3 minutes)
any help would be great. this is my everyday driver. i need this running asap (now)
thank you guys
thank you guys
ok i got the car running.....it was the ignition fuse it was loose not blown but anyways the car is now breaking up at high RPM and low rpm but only somtimes i dunno what do you guys think it could be???? i am thinking opti
U need to check two things-
ignition and fuel
Check fuel first- Hook a fuel pressure gauge up to the valve on your fuel rail. THe valve is behind your intake manifold facing towards the drivers side at an angle.
If u have 36-40psi and its still breaking up its not your fuel.
CHeck your plugs and wires next
then if those check out its your opti... very likely anyways
ignition and fuel
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
