car wont start or breaks up
Old Mar 24, 2008 | 02:59 PM
AN7967's Avatar
i have a 1993 camaro z28. sometimes it wont start and if it does it idles real low and breaks up in high rpm. but also sometimes it will run fine. what could it be?
Old Mar 24, 2008 | 04:37 PM
ss.slp.ls1's Avatar
Could be several things. How is the fuel pressure? How old is the coil, opti, and icm?
Old Mar 24, 2008 | 04:55 PM
Have you scanned it for codes?
Courtesy of Shoebox:
http://shbox.com/1/dlc2.jpg
Old Mar 24, 2008 | 04:56 PM
dangalla's Avatar
if there is no codes i would check these pretty much in this order
Old Mar 24, 2008 | 09:08 PM
AN7967's Avatar
the coil, spark plugs, spark plug wires, fuel pump, fuel filter have just been replaced. i was thinking the opti but somedays it will run just fine without breaking up or idling low. and the only code i got was an o2 sensor.
Old Mar 24, 2008 | 11:42 PM
ss.slp.ls1's Avatar
Sounds like you got it all covered but the opti dude. If its the original, then its past its time.
Old Mar 25, 2008 | 09:04 AM
What SPECIFIC O2 sensor code did you get?
Old Mar 25, 2008 | 11:01 AM
AN7967's Avatar
i thought it was the opti from the begining. but didnt wana spend the money if i didnt have to cuz i have a 4 bolt 383 going in it. but thats down the road a lil after i buy heads. so ima replace it cuz it is original. i forget what the specific code was but it was #13 nd it was the left 02 sensor
Old Mar 25, 2008 | 11:36 AM
ss.slp.ls1's Avatar
[QUOTE=AN7967;5268444]so ima replace it cuz it is original.
Yeah, factory opti's time is up, even if it wasn't bad, its good preventative maintenance.
I would take care of that, swap sensors from left to right and see if the code follows. If it does, then replace the bad sensor.
Noenav
Mar 1, 2019 07:38 AM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
Dave19yz28
Jan 26, 2003 01:45 PM
formula79
Aug 24, 2002 12:02 PM
