Car Won't Start After Cam Swap. Need Help
Old Jun 19, 2008 | 12:00 AM
TAEnvy's Avatar
Hey guys my car sat for 2 or 3 months while it was getting a cam swap. Well the cam is all done and the mail order tune is in. Its a 306 cam and I started her last night without the tune and she ran great til I ran my hand over the maf (I started it without the Cold air intake on) and then a loud back fire and wouldnt start back up.
Foudn out the starter was split, got me a new starter, and she fired up then died right away.
She'll start now, but its kinda scratchy when tis turnin over, I figured it was the starter, then as soon as it starts it immediately dies. If you give it a bunch of gas you can delay it a little.
Any ideas? Or things I should start with first?
Car is a 1997 Z28 6speed.
Mods are
Ported Maf
K&N CAI
!EGR !EVAP !AIR !CPS
CC306
Cloyes Double Roller (Checked and Checked Clearances)
CC Pro Mag 1.6 NSA Rockers with guide plates
10308 Spring Kit
LS7 Lifters
LTs
Deleted cats and rear o2s.
Seems like it ran better with the stock tune. Idled really freakin high but at least it would stay running.
Car did the same thing when I tried to sea foam it a long time ago which was causing a big vacuum leak.
Old Jun 19, 2008 | 07:54 AM
irocbsa's Avatar
Sounds like you still have starter issues. If its makes nasty grinding noises when the starter is engaged, the starter gear is not meshing correctly with the flywheel/flexplate. You might need to get some shims to get the right contact pattern.
As far as the "runs then dies problem", unplug the MAF, see if improves. Post back. I always get nervous when I hear "ported MAF".
Old Jun 19, 2008 | 08:30 PM
TAEnvy's Avatar
So A buddy came over and I tried to start it and it fired up and I kept it runnign for a few seconds and he freaked out cause a big flame shot out of the intake track. I was running open maf without the K&N on.
You think it could be the maf, Im sure tis ****ed now?
Maybe I have the rockers to tight and its keeping an intake valve open?
But then why would it have ran with the stock tune?
ALso I unplugged the maf and tried and its no better. It still dies but I just let it fire then didnt give it any gas so it died right away. Do I need to try and keep it runnign with the maf unplugged and see if ti clears up?
Also dont forget there was a bad backfire on the stock tune when I ran my hand over the maf
Noenav
Mar 1, 2019 07:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
