Car won't run. Fans come on when the key is ON
Old Aug 20, 2005 | 07:04 PM
  #16
slopokrodrigez's Avatar
Re: Car won't run. Fans come on when the key is ON
Take your PCM to an Auto-Value store and have them reflash it for $69.00. If it is shot, they can tell you. Otherwise you have a wiring issue you need to resolve.
Old Aug 22, 2005 | 03:32 PM
  #17
Stoopalini's Avatar
I had a very similar issue that turned out to be the pigtail connector for the coolant temp sensor. I used a scanner to read all sensor data, and the coolant sensor was reporting -40'F. I unplugged the pigtail and used a very small screwdriver to close the gap in the individual connectors inside th epigtail; basically, I made the connections tighter. After plugging back in, the temp sensor reads correctly and problem solved.
Just something to consider,
Thomas.
liamcg97
Nov 25, 2019 05:55 PM
1775.Z28
Jan 11, 2015 10:51 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
x7x7
Aug 15, 2002 06:49 PM
