Car won't run. Fans come on when the key is ON
I have a 95 LT1 all stock. The car was running fine. Now when starting the car. The fans come on with the switch in the ON position. The fuel pump will only prime for about 2 seconds, and does not come back on once the cars starts. So it dies after about 3 secs of running.
Thanks for any help
Thanks for any help
Re: Car won't run. Fans come on when the key is ON
the fans are comming on because the car is running in limp home mode, thats something that the computer does when theres some serious sensor problems.
check the m.a.f. sensor, make sure that the hose isn`t cracked or fallen off the throttlebody. also check to make sure that the maf is clean and dirt free.
the coolant temp sensor will also cause it to run in limp mode, its in the waterpump check to make sure that it`s plugged in.
also at this point you should be able to scan it and get the code to find out whats wrong with it.
I tried another pcm, and it still does the same thing. Your right on the priming. It does what it is suppose to do, but once the car starts the fuel pump will not come back on. Is there a way to get the car to flash trouble codes on the 94-95 cars? Yes it also has a OBDI 8051 pcm.
Thanks Again
Thanks Again
You must use a scanner to get trouble codes.
How are you verifying that the pump is not running? The PCM will not allow the pump to run if it does not see any activity from the opti. You need to retrieve the trouble code(s) and see what is going on.
Shoebox, I went and got my laptop and cable. I tried to use freescan to read any trouble codes. The freescan software will force data between it and the pcm, but does not return any engine data or trouble codes. It shows bytes recv and send to be equal, the pcm is not volunteering any info back to freescan. Any ideas.
If you have no SES (or did not have before), there may be no codes to retreive. You asked about scanning, but really didn't indicate that there was ever a SES.
Its weird that the freescan can not comm. with the pcm. I just tried it again and the car will start for about 2 sec. then dies. I'm 100% sure the fuel pump is not coming back on. I get no SES codes or Security Light flashing.
The car must be frying them somehow. The pcm on the car came from a running car. The only other pcm I have to try is a 96 OBDII will it fire the car? I never have tried swapping to a 96-97 pcm on a 94-95 car.
