new engine running but i have a problem
Old Aug 22, 2005 | 03:27 PM
LT1powered94's Avatar
I finally got my new motor running. The exhaust is smoking like crazy. i think its coming from the y pipe where it meets the manifolds and on the bottom end. This is my stock exhaust. I didn't put any gaskets in there b/c there weren't any in there when i took it off. Could this be stuff burning off (i've only run it for 5 minutes)? Is there any damage I could to driving it this way?
Old Aug 22, 2005 | 03:33 PM
BlownF1's Avatar
Re: new engine running but i have a problem
I haven't seen any systems that don't require gaskets, but which one are you running? More details would be helpful. It's not uncommon for a bit of gaskets/fluids to burn-off on a new engine, but when you say "smoking like crazy"...that's a bit concerning. You need to figure out where it's coming from for sure...
Old Aug 22, 2005 | 03:44 PM
Black1995Z's Avatar
Did you adjust the valves with the valve covers off? If so, there is probably oil all over your exhaust. It took mine a long, long time to burn. And it looked like a bbq!
Its stock. I'm not saying there shouldn't be any gaskets in there. I'm saying there weren't when i took them off and it wasn't smoking. So I thought i could get away with no gaskets when I put them back on. I really am hoping to get but with this stock exhaust for a couple months still i can find some time to put new exhaust on. You know how tight it is in there. I can't tell exactly where it is coming from, but when I fired it up, I thought i had a #8 wire barbicue. Shortly there after the drivers side was smoking. I look under the car and i had smoke before the cat. I'm gonna see if I can get it out of the garage and test drive it.
Old Aug 22, 2005 | 03:46 PM
No the valve covers went on before the exhaust. But thats not to say I didn't some how get oil on them. Maybe (hopefully) thats it.
Old Aug 22, 2005 | 04:17 PM
Black1995Z's Avatar
If the car is running smoothly, I'll bet its just fluids burning off.
Plus, oil takes a while to burn off completely and its a dark smoke.
dirtybird81
10
Jan 6, 2015 09:31 PM
97SSdude
Dec 31, 2014 07:43 PM
Jazsun
Dec 29, 2014 12:14 PM
Lions3
Apr 11, 2003 10:55 AM
