Car stutters and bogs down, then drives fine the next day??
Old Jun 17, 2013 | 12:08 PM
Reffett2010's Avatar
I just bought a 93 z28 and it drove and ran fine when I test drove it. Drove it almost 2 hours home and everything was fine until i was 4 miles from my house. When accelerating out of town it sputtered 4 or 5 times then it was fine. 2 miles later i set the cruise at 65 mph heard some clinking under my feet and my car started to bog down. Every time I pushed the gas the car wanted to die. It shook real bad and ran like crap. Turned it off and tried to start it. It cranked and cranked but nothing. Couple minutes later it cranked and started but ran low rpm's and died. I finally was able to drive it back at about 35 mph in the same condition pulled in my driveway and it died. 5 minutes later tried to start it crank crank crank crank nothing! Later that night it started just fine and drove normal. Today it seems fine also. It has magnaflow exhaust, with stock manifolds. Car has 111,500 miles and it sat for about 2 years. Sorry for the long story but I hit a deer and totaled my other car now I have no vehicle until my camaro is fixed!
Old Jun 17, 2013 | 03:31 PM
slick1hunting's Avatar
I would scan it for codes. I also would check fuel pressure. The noise at your feet and some of your symptoms might have me question your catalytic converter.
Posted from Camaroz28.com App for Android
Old Jun 17, 2013 | 08:20 PM
Re: Car stutters and bogs down, then drives fine the next day??
Mechanic plugged it in and said everything looked fine 02 sensors were working fine. Only code I got was to do with EGR valve. Maybe it stuck and caused that. If there was a problem with the cat converters would that have thrown a code?
Old Jun 18, 2013 | 12:38 AM
TaskForce141's Avatar
Bad check valve??
Old Jun 18, 2013 | 09:13 AM
STSturboLT1's Avatar
I would check fuel pressure first. Your pump might be going out which would explain why sometimes it works fine and other times it won't even start. Fuel pumps can act like that when they're dying. Maybe the noises were from the vibrations from the stumbling motor?
Old Jun 18, 2013 | 02:10 PM
Do you realize that on a 93 LT1 (that year only) you can flash the codes on the SES light?
Courtesy of Shoebox:
http://shbox.com/1/dlc2.jpg
http://shbox.com/1/Dtcs.htm
Which EGR codes did you get? There is one for the electrical circuit to the EGR vacuum solenoid, and another code for low EGR flow. You need to post the exact numbers, not just the descriptions.
There are no codes in OBD-I that are related to the cat converter performance.
Look at things that can heat soak - the ignition control module (ICM), the optical cam position sensor in the Optispark distributor and the fuel pump are a few tings that come to mind.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
nophix
Nov 30, 2014 10:26 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
