Car still burns oil!! [edit]! Help me please!
Old Sep 12, 2005 | 10:10 PM
  #31
Jameslt1TA's Avatar
Re: Car still burns oil!! [edit]! Help me please!
Originally Posted by Robs97Z28
The simple fact that your problem stopped after you replaced the valve stem seals. Meaning no smoke! Now a few miles later, the problem has come back. Tells me that your guilds are worn.
The only way to fix this problem is to pull the heads and have a valve job done. Have them surface the heads, too
Correct me if im wrong but i dont think the valve guides wether new or worn do much in the way of keeping oil out. Im not sure but when i did a valve job on my heads i didnt touch the guides.
I mean if you took off the valve seals on brand new heads or some with 200k it would burn oil either way wouldn't it?
Not trying to be a dick im just unsure.
Old Sep 12, 2005 | 10:20 PM
  #32
jchevy's Avatar
I agree 100%.
Old Sep 13, 2005 | 09:44 AM
  #33
Jazsun's Avatar
No, that is wrong. The problem never stopped and then came back again. What happened was, after replacing my valve stem seals it stopped smoking on cold start, but still puffs white/grey when hot(which it has always done)
Old Sep 13, 2005 | 11:52 AM
  #34
Evil Eric's Avatar
Originally Posted by Jazsun
I recently installed new felpro valve stem seals
Originally Posted by slimdawson
Could be your valve seals.
I think he covered that. Check the torque on you intake manifold. You might have an intake gasket leaking from the inside, I dont think that would be unheard of. It would only take 1 out of the 16 seals to be messed up to burn a little oil at startup. when my car was doing the same thin i only had 2 seals that were really torn/leaking bad. A new set of Felpro's solved the problem. Also, how new is your PCV valve?
how many miles are on this car?(if it hasnt already been asked)
Old Sep 13, 2005 | 05:40 PM
  #35
Jazsun's Avatar
Im positive that the valve seals are good, they are all brand new. I checked the pcv valve a while back and shook it, and the little flap thing moved fine. (duno if thats the problem w/ it but that part worked). Car has 100k onit. To check torque on intake manifold would I need to remove anything? Whatare the torque specs? Thanks for the help.
EDIT: Also the old seals I took off didnt look bad no tears or anything but I think some of them slide off of the valve guides and up onto the stem some which caused a big part of it.
Old Sep 13, 2005 | 09:30 PM
  #36
Robs97Z28's Avatar
I do care if you put 100 new seals on, if the guides are worn they will never seal. The valve guides are meant to keep the in a stright up. Since the guode wear out they can close at any angle. Which would make the seals deflect and aloow oil to slip by.
Old Sep 13, 2005 | 09:54 PM
  #37
Jameslt1TA's Avatar
There that makes sence...duh i couldnt figure it out, why the guides would do it.
But given the amount of miles you car has already i think it would be a waste of money to just pull of the heads only to fix it from smoking alittle bit. Just wait until you do a rebuild.
Old Sep 13, 2005 | 10:16 PM
  #38
Jazsun's Avatar
Ya im not gona fix it. Im sick of this ****. So Ill just let it burn.
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
Bando
Aug 2, 2002 02:18 PM
