Car still burns oil!! [edit]! Help me please!
Old Sep 9, 2005 | 08:59 PM
  #16
Jameslt1TA's Avatar
Re: Car still burns oil!! GOD DAMIT! Help me please!
Originally Posted by Jazsun
Well when I see myself putting oil in it I question why I am modding it...Isnt it dumb to mod a car which burns oil! I think so!
I was modding it because I was confident it was the valve stem seals which was causing the oil brun, and now that its not I am pissed. Car just turned 100k.
No its not dumb to mod it. If you've got compression then you are good to go. Like i said all cars will burn alittle bit of oil.
Old Sep 9, 2005 | 09:01 PM
  #17
Jazsun's Avatar
Is 1 quart every 1500 still good to mod? lol
Old Sep 9, 2005 | 09:04 PM
  #18
Jameslt1TA's Avatar
Well after asking you many times how much it burned you finally answered. Jfyi my car at 80k burned 1 quart a month and i drove it 200 miles a week and it ran fine. I wish i would have just modded it that way instead of being paranoid and rebuilding it only to have it blow up.
Old Sep 9, 2005 | 09:19 PM
  #19
Jazsun's Avatar
I am just curious as to what u think it is since its not my valve seals?
Old Sep 9, 2005 | 10:01 PM
  #20
Jameslt1TA's Avatar
Hmm maybe your oil rings...they dont afect your compression...at least i dont think they do.
Old Sep 9, 2005 | 10:56 PM
  #21
aintno6's Avatar
My car does the same thing yours was doing.
Here is my idea. I dunno about you, but my exhaust pipes are coated with an oily film due to the long term neglect of fixing my valve seal/guide. So I personally think that once the the pipes/headers reach a certain temp, its burning this remaining oily coating inside the pipes off.
Just an idea.
Mike
Old Sep 10, 2005 | 12:23 AM
  #22
Originally Posted by shoebox
I find your thread title offensive.
You're not the only one. Hard to believe people feel they have to offend to get attention. I "edited" the topic.... more wasted time I could have spent helping someone with a problem.....
Jazsun
I know you're frustrated, but please don't do that again.
Old Sep 10, 2005 | 12:34 AM
  #23
SoloExceptional's Avatar
Re: Car still burns oil!! [edit]! Help me please!
Someone may have said this, but I would look at the head gaskets, and all your gaskets around the oil pan. Do you smell anything? What kinda oil do you use? Cause I personally haven't had a car that ate oil like that, but from my understanding it's normal.
Old Sep 11, 2005 | 09:08 AM
  #24
Jazsun's Avatar
I use Castrol GTX Startup 10w-40. I do have some oil seepage near the bottom of the motor but I cant tell where its coming from. It doesnt leak, like leave spots on he driveway but I can see a little seepage when I get under it. Its kinda where the balancer/crank pulley is.
EDIT: I dont smell anything either.
Old Sep 11, 2005 | 09:10 AM
  #25
Jazsun's Avatar
Just an idea.
Mike
Thats a good idea, but you wouldthink once it does reach that temp that it would burn while dirving not just startup. But I do know that fixing the seals has been neglected for a while.
Also I have a new catback so the only spot would be the headers.
Old Sep 12, 2005 | 06:50 PM
  #26
Jazsun's Avatar
Ok today I looked at it, and the smoke actually appears to be a greyish/white. I did notice a while back that my coolany smelled like major *** and was brown but I thought it was from rust. Is this a blown head gasket or something or what?
Old Sep 12, 2005 | 06:58 PM
  #27
Jameslt1TA's Avatar
That could be...the smoke would be from it burning coolant. The problem doesn't sound too bad but i would definetly replace the head gasket, that is if its the problem.
Have you noticed the coolant level going down at all? It may just be a small, slow leak.
Old Sep 12, 2005 | 07:14 PM
  #28
Jazsun's Avatar
Actually I just checked andthe coolent level has never gone down ever since I owned the car(using the coolent dipstick to check). Which is wierd but it does smell like crap and is brown, a friend of mine said that the brownishness /redish is probably from rust within the radiator. I did flush the radiator not too long ago(and bleed the air out), but not the block so I didnt get all of it out so it still is redish/brown.
Are there any other sources form which water or something of that kind could be coming from besides head gasket?
Thanks for the help James you seem to be my only hope.
Old Sep 12, 2005 | 09:04 PM
  #29
Jazsun's Avatar
bump
Old Sep 12, 2005 | 09:54 PM
  #30
Robs97Z28's Avatar
The simple fact that your problem stopped after you replaced the valve stem seals. Meaning no smoke! Now a few miles later, the problem has come back. Tells me that your guilds are worn.
The only way to fix this problem is to pull the heads and have a valve job done. Have them surface the heads, too
