Car stalling out after 10-30 minutes of driving
Old Aug 22, 2010 | 08:03 PM
kumho's Avatar
Starting a few weeks ago my 1993 Camaro Z28 has begun to stall out more and more frequently. Usually after 10-30 minutes of driving. It seems to happen sooner on hot days. What will happen is the engine will just shut off without warning like the key has been turned off. It will usually start back up right away and run fine. I replaced the ICM, and it didn't help. Now I think its the Optispark again.
In addition to stalling, sometimes it will be like I've hit a limiter and rpms will just shoot back down. Usually when i'm getting on it. Like hitting 4k and immediately bouncing way down. Today it backfired for the first time and is running like crap. Jacked the car up and pulled off my plug wires to take a look. On one of my wires the metal is browm/burned a bit on the inside. The matching metal connector on the opti is discolored compared to the others.
I replaced my optispark last year, but it almost has to be the opti again, doesn't it? I know the bad wire wouldn't have caused the stalling, but could a hot opti randomly stall like that? I'm pretty sure today when my car backfired it was the opti burning out that plug wire.
Probably unrelated, but my temp gauge went out a month or two prior to this. I've been driving without a working gauge, but I'm pretty sure its never overheated, never had coolant overflowing.
Old Aug 23, 2010 | 01:19 AM
Red_94Formula's Avatar
Sounds like the opti to me. If its burned its prob junk. Changed that one burned wire as well. Maybe a cap and rotor will work for you.
Old Aug 23, 2010 | 05:19 AM
Have you checked for codes?
Noenav
Mar 1, 2019 07:38 AM
Injuneer
Dec 15, 2014 09:36 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
