I broke this.
Old Aug 20, 2010 | 01:12 PM
Rob94hawk's Avatar
I broke this.
Before I pulled the motor I went to disconect it but snapped it right off instead. First, what is it? Second, part number.?
I spent a half hour looking through the manual and can't find it. Pic is a little blurry but as you can see it's on the back of the block. Thanx
[IMG][/IMG]
Old Aug 20, 2010 | 01:28 PM
RamAir95TA's Avatar
That's your oil pressure sensor. It's VERY common to break as it's very fragile. It's GM part number 10201491.
Old Aug 20, 2010 | 01:31 PM
Rob94hawk's Avatar
Much appreciated.
Old Aug 20, 2010 | 01:35 PM
z0s0's Avatar
yep, and I broke mine too this spring doing my heads. Then I broke the replacement I bought while installing it, be careful when you put a wrench on the new one.
Old Aug 20, 2010 | 02:13 PM
1badeagle's Avatar
Its funny that you mention that. I broke my new one during the install. How tight is tight?
Old Aug 21, 2010 | 02:49 AM
ACE1252's Avatar
Torque spec is 106 in-lb. There is an oil pressure sensor socket you can get at Autozone, Advance, etc.
http://www.autozone.com/autozone/acc...er=141490_0_0_
Old Aug 23, 2010 | 09:58 AM
97FormulaWS-6's Avatar
Mine cracked and seeped oil for about 2 years before I found it... I only found it cuz I pulled the motor to freshen things up...
truecontr3
Oct 11, 2015 09:30 AM
frankrizz
Sep 23, 2015 04:21 PM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
