Car Shakes Gently at Idle and High Speed Low RPM???
Old Apr 7, 2010 | 02:46 PM
  #16
FastandBlue's Avatar
Yeah I just found some information on replacing them and I don't think it should be too bad. I'll actually make sure that's the problem later today after classes are over. Dang, college is keeping me busy and after this it's med school... I have a strange feeling I won't have much time to work on this car when that rolls around!
Old Apr 7, 2010 | 03:04 PM
  #17
94CamaroZ28/SSClone's Avatar
Pretty sure, when you replace the mounts. You wont have the shaking problem no more.
Old Apr 7, 2010 | 10:24 PM
  #18
Yeah, the problem is getting a little worse. . . .uh oh. It's definitely more of a problem at low RPMs than high, especially with soft acceleration and gentle deceleration. I'm putting it on jackstands again tonight and I'll order new engine mounts pretty soon. Is there a mount that's better than another? Here's an option:
http://www.rockauto.com/catalog/rafr...035908k1015560
Old Apr 7, 2010 | 11:23 PM
  #19
I don't know? I went with stock mounts with My Buick.
Old Apr 9, 2010 | 12:22 AM
  #20
Okay, so I put the car on jacks and started it. The engine runs smooth as ever, but the engine mounts, particularly the left one (if you are looking toward the rear of the car) is moving back and forth quite a bit. The rubber on both is old with tons of micro-cracks in it, even though it is still intact for the most part. What do you all think? Engine mounts need to be replaced? Will that fix the gentle shake at low RPMs and while idling? Thanks!
Old Apr 9, 2010 | 12:27 AM
  #21
I say its time to replace them! Thats the problem!!
Old Apr 9, 2010 | 12:29 AM
  #22
Alright....Time to do this. I also hear a bad EGR valve can cause bucking on acceleration, which is also occurring. The EGR is a bit cheaper to fix first. What do you think I should try first. The mounts or EGR?
94Camaro:
Did you car "buck" on acceleration with the bad engine mounts, too?
Old Apr 9, 2010 | 12:33 AM
  #23
Do both! Your crossing out two items off the list. EGR valve then Mounts. If it bucks as you say it when you accelerate it means the engine literally jumps off the engine mounts.
Old Apr 9, 2010 | 12:48 AM
  #24
Hmm, it doesn't really buck hard--I describe it more as lugging when the rpms are low and I'm speeding up lightly from 45-50mph.
But yeah, it's obnoxious so I might as well do both. *sigh* What do you guys think about Rock Auto Parts? They sell AC Delco EGR valve there for $67.00.
Old Apr 9, 2010 | 02:05 AM
  #25
Air-Adam's Avatar
You say it only happens in gear... I wonder if it might be engine-load related? What does it do in 'P' with the A/C on, or any other means of loading the motor at idle?
Old Apr 9, 2010 | 04:07 AM
  #26
That's what I'm leaning more towards, but a few people are telling me this can be caused by the bad EGR and engine mounts. The gentle shake is exaggerated in gear, but it does gently shake while idling, too.
Basically, it happens when I am idling whether I am in gear or not, when I accelerate softly at low RPMs while driving between 45-55mph, and when I decelerate under 5 mph. It's not that bad at all, but it is definitely noticeable while going 45-55mph. If I shift up a gear and take it out of overdrive, the RPMs go up to 2200 and then it feels smoother again.
Old Apr 10, 2010 | 12:38 AM
  #27
Fatdog2's Avatar
Before you go and throw money on stuff,I would check for vacuum leaks.Those little hoses on the pass side of the engine,ect.If you haven't had the intake manifold gasket replaced,this could be a problem.hope this helps.
Old Apr 10, 2010 | 12:45 AM
  #28
Fatdog2's Avatar
Sorry,this also sounds electrical.I re-read your post three times,and it kinda sounds like this.Beer time here.(OPTI)
Old Apr 10, 2010 | 03:42 AM
  #29
Not OPTI! I have had Opti failures two times. What he is experiencing is not Opti related. ENGINE MOUNTS!
Old Apr 10, 2010 | 04:07 AM
  #30
Fat dog, it does. I don't think it's the opti. It's pretty much brand new. Vacuum leaks make more sense, but I am noticing quite a bit of engine movement when blipping the throttle, so I might as well replace the mounts first and go from there. There is a slight hissing coming from the driver's side of the radiator. Any ideas there?
