CAr runs kinda hot with a CSI
Old Mar 27, 2004 | 08:35 PM
  #16
97WS6SCharged's Avatar
I'd go with a nice 160 deg. thermostat and some of this...
http://www.royalpurple.com/prodsa/prpice.html
My car (with a CSI pump also) stays around 170 with the AC on in the summer here in Jax, FL.
Old Mar 28, 2004 | 06:29 AM
  #17
xxsaint69x's Avatar
Originally posted by Z95m6
If your just breaking in your engine then there could be excess heat from the break in. I know you have a 355 but i guess i don't know if your just now getting it running or have been for a while.
ya i am just breaking it in. Only 40 miles on it
I used 14 guage wires.
Old Mar 28, 2004 | 08:14 AM
  #18
wicked_95z's Avatar
I've never tried it myself but my machinist uses that water wetter stuff in his race car and he said it works. Might want to try that
Old Mar 28, 2004 | 04:47 PM
  #19
xxsaint69x's Avatar
hmm i dont know, i did a search on this and looks like i am not he only one having this problem THERE IS NO AIR IN THE SYSTEM!!!! What should i check next?
Old Mar 28, 2004 | 06:11 PM
  #20
DrivinSidewayz's Avatar
use bigger wires... atleast the size of the csi wires... 14 gauge is smaller than 12... you should have to use any water wetter or anything, my csi also keeps the temp right above 160 under any condition, also where did you conect the power wire to? did you connect it to the red little box thingy on teh passenger side?
Old Mar 28, 2004 | 06:17 PM
  #21
12SCNDZ's Avatar
Mine never gets above 180* with the CSI.
Frank
Old Mar 28, 2004 | 06:30 PM
  #22
Compstall's Avatar
I am also having a small issue w/ heat since I installed my CSI. When I'm driving around w/ plenty of airflow it runs cool. But when I'm sitting idle the temp likes to creep up on me. So I re-installed my 160* thermostat and it runs a little cooler while driving, but STILL creeps on me when sitting idle. So I just turn my fans on and knock it back down. I can't figure it out myself either.
I have been trying to find a bottle of Water Wetter here in Albuquerque but haven't yet. My mixture is 50/50, and I can't find any leaks...
Old Mar 28, 2004 | 06:36 PM
  #23
xxsaint69x's Avatar
hmm....i doubt that 12 guage wire will have any effect
a relay is hooked up the battery and then it runs to the fuse on the driver side..... anything wrong with that
Old Mar 28, 2004 | 06:40 PM
  #24
Compstall's Avatar
My relay harness wire is thicker than the wire that came with the water pump as well....
Old Mar 28, 2004 | 07:11 PM
  #25
xxsaint69x's Avatar
the weird thing about mine is that it wil get the car down to 193 (both fans turn on at 193) at idle..you can have it sit for 20+ min in sun and it wont move up or down constant 193. As soon as i start driving it will go up to around 204 and sit there....as soon as u stop it drops down to around 193.....wtf?
Old Mar 28, 2004 | 07:13 PM
  #26
Compstall's Avatar
I just figured if I can't figure it out, before too long I'll just throw in a GOOD oil cooler and go from there.
Old Mar 28, 2004 | 07:42 PM
  #27
shadydavy 95 TA's Avatar
Exclamation
I remember an old thread about this subject...something about the pump not turning as much as the stock one at highway speeds. Meaning that it turns enough to cool the car at idle but not at highway speeds. Not sure if there is any truth to this, but in some ways it makes sense.
You would think it would run cooler rolling down the highway.
Old Mar 28, 2004 | 07:45 PM
  #28
Compstall's Avatar
Read MY first post.
Old Mar 28, 2004 | 07:53 PM
  #29
So I just stated what your post implied?
Now I'm confused, and I don't even own a CSI water pump. Good luck figuring it out though.
Old Mar 28, 2004 | 07:59 PM
  #30
Mindgame's Avatar
Your temp sounds about right when you consider that it's a new engine w/stock thermostat.
I wouldn't worry about it. Get a 160º in there if you want to keep the avg. temps cooler.
-Mindgame
