Car overheating!?!?Help!!
Old Jan 14, 2005 | 03:28 PM
  #16
Randomsoleil's Avatar
Re: Car overheating!?!?Help!!
also make sure since you have a 97 you have the high milage coolant..and unless you have done a complete flush of the engine and coolant system you need to make sure you only use the high milage stuff if you try and mix it, it has a tendancy to slush up
Old Jan 14, 2005 | 03:43 PM
  #17
SilverStreak's Avatar
Ok so here it is....
Coolant was fine, yes i was use the dex cool crap (orange expensive stuff from hell as i like to call it).
I don't really see how you can put a thermostat in wrong it's kinda fool proof... but then again nothing's fool proof because people tend to forget fools are so engenious....
It was turning the right way although a great idea, if wired backwards well enough said because it would pump backwards.. but it had a black and blue wire... black = ground no brainer....
BUT
It's working.. thanks to my friend bob at the chevy dealer hehe.
it would seem that the wire we spliced into was a 5v source instead of the needed 12v source. I wasn't in charge of the wiring but i know we check the resistance with a meter and all that crap and well... i guess we goofed.
Thanks for all the input everyone! looks like i'll make it to class and work after all!
-Chris
Old Jan 14, 2005 | 03:48 PM
  #18
Oh and i alsmot forgot.. yes we bleed the system and yes it was happening while cruzin... so no airpocket.. and also when i changed the oil no "latte" lookin stuff anywhere so no water leaks.
Old Jan 14, 2005 | 03:52 PM
  #19
well glad to see you got it working...i know when i was having my overheating problem it was anoying as hell....atleast yours was an easier fix...i ended up having to do a full rebuild..ok not having to but why the hell not
Old Jan 14, 2005 | 04:00 PM
  #20
Annoying doesn't begin to discribe it! But yeah a rebuild would be fun! other then the fact i had to just spend 2 grand on this semester.... and well the money i was savin up for headers.... just went down the drain fixin the heating problem... i swear i think i'm cursed!
Old Jan 14, 2005 | 04:08 PM
  #21
yeah i had to use my beater car money to do the rebuild
Old Feb 8, 2005 | 02:11 PM
  #22
blind527's Avatar
my car runs sweet
when i'm driving it is at the second mark past 160, but when i'm idle it heats up a little bit, solutions?
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
