car hard to start after rerouting wires
Old Jun 21, 2007 | 06:23 PM
reamo04's Avatar
we just rerouted my wires to get them off of the PS pulley, and changed my accessory bracket too. Before we did all of this, the car would start pretty quick, now it takes 3-4 seconds to start. What could be some things that I could check? I checked all my wires, and they are all on there pretty good. Could it maybe be since my car sat for a week and maybe my battery started to drain down or something? What would you guys check
Old Jun 21, 2007 | 06:27 PM
I would check the wires again (or anything else you messed with).
Old Jun 21, 2007 | 08:16 PM
reamo04's Avatar
i have, checked the wires again, their all fine on both ends, alternator is fine. Starter is clicking, but it just takes a while for the engine to finally crank over. The only thing thats different now is that i have a code 15, could that cause this?
Old Jun 21, 2007 | 09:17 PM
Nitelite's Avatar
A weak battery by chance?
Old Jun 22, 2007 | 12:45 PM
reamo04's Avatar
it turns over fine, trickle charged the battery, and still no gain. What a couple people think is the temperature sensor may be bad, which causes it to not know how much fuel to put in?
Old Jun 22, 2007 | 01:01 PM
JAB's Avatar
JAB
That is the reason. I had that same problem for awhile until I found the ground wire had been cut while we were doing the headgaskets on my car.
Old Jun 22, 2007 | 01:06 PM
reamo04's Avatar
any idea on if its the waterpump one probably? Im just getting ticked off at it because i cant find where it could have possibly got pinched or anything, its not behind the bracket or anything
Old Jun 22, 2007 | 01:13 PM
JAB's Avatar
JAB
It IS the waterpump sensor. The sensor in the radiator you mentioned won't set a code. It's only connected to the light on the dash.
Old Jun 22, 2007 | 01:18 PM
reamo04's Avatar
well, i know theres another one in the head, i didnt know if it was that one, or the WP one.
Old Jun 22, 2007 | 01:20 PM
JAB's Avatar
JAB
The one in the head is only connected to the temp. gauge in the dash. That one doesn't send it's signal to the PCM. Only the WP sensor does.
Old Jun 22, 2007 | 03:32 PM
2000GTP's Avatar
If the sensor in the WP itself is malfunctioning, that could very well lead to a hard start condition.
Old Jun 22, 2007 | 03:48 PM
reamo04's Avatar
we've decided its either the sensor in the WP, or the wiring leading to it. Is there any way to check the wiring?
Old Jun 22, 2007 | 03:55 PM
2000GTP's Avatar
Shoebox has a good tutorial that covers it all.
Old Jun 22, 2007 | 04:41 PM
I made that suggestion in the first reply to his thread regarding code 15. You can lead a horse to water...
Old Jun 23, 2007 | 12:16 AM
reamo04's Avatar
got it all taken care of, thanks guys
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
CobraEatr
Jul 29, 2002 11:46 AM
