Car died while driving
Old Aug 20, 2019 | 02:17 PM
Logan Jones's Avatar
I have a 93 z28 A4 and The last few days the car has been like almost dying at times while driving. The car feels like it shuts off but then kinda turns itself on and drives. Today on my way to school the car actually died and I had to pull over and turn it back on. It took a few seconds then longer to crank but turned on and drove. On the way home it almost died but it kinda revved itself up a little bit when it happened and the car kept going. I noticed this morning when I first turned the car on it was reviving as if it had a vacuum leak. I also noticed the car has a small crack in the fresh air Pcv hose and I don’t know if this could have something to do with it? The car also sometimes will hesitate once at highway speed.
Old Aug 20, 2019 | 02:53 PM
Re: Car died while driving
Did you check for codes? Do you have a way to test the fuel pressure?
Old Aug 20, 2019 | 03:03 PM
Just got home I’ll check for codes soon and no I’m not sure how to do that. What would I need to do it
Old Aug 20, 2019 | 04:34 PM
What are you not sure about how to do - checking for codes, testing the fuel pressure, or both?
Old Aug 20, 2019 | 09:03 PM
I know how to check the codes with a paper clip. I have to wait till I get home tomorrow so I can check the codes after driving. I just don’t know how to test fuel pressure
Old Aug 20, 2019 | 10:17 PM
You hook a fuel pressure test gauge, with a long hose, to the test port (Schrader valve) on the fuel rail assembly. On a 93 (only) the Schrader valve is on the driver side fuel supply hard line near where the flexible lines connect to the hard lines (which attach to the fuel rails).
You can usually borrow (or rent) a test gauge from many auto parts stores.
https://www.amazon.com/OTC-5630-Fuel-Pressure-Test/dp/B000R5IASC/ref=asc_df_B000R5IASC/?tag=hyprod-20&linkCode=df0&hvadid=312142020868&hvpos=1o2&hvnetw=g&hvrand=373519135627695893&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9004005&hvtargid=pla-403890609833&psc=1 https://www.amazon.com/OTC-5630-Fuel-Pressure-Test/dp/B000R5IASC/ref=asc_df_B000R5IASC/?tag=hyprod-20&linkCode=df0&hvadid=312142020868&hvpos=1o2&hvnetw=g&hvrand=373519135627695893&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9004005&hvtargid=pla-403890609833&psc=1
Old Aug 20, 2019 | 10:19 PM
Since you don’t have a pressure test gauge, focus on pulling the codes first.
Old Aug 21, 2019 | 03:05 PM
I haven’t ran the codes yet. I’ll have to do it soon but I think I found a problem. Considering there’s black tape connecting a fuel line that is laying in the engine. What’s should I do about this and could this cause the problem?
Old Aug 21, 2019 | 04:20 PM
That looks like the EVAP purge line that connects to the black EVAP purge solenoid. The bracket the solenoid connects to appears to have broken or fallen off. It should be screwed onto the side of the intake manifold, see the screw hole in the manifold right behind the tape.
While that line runs from the back of the car near the fuel tank, and is bundled with the fuel supply and return lines, it is used to pull fuel vapor out of the carbon canister in the driver side rear fender, near the gas tank fill pipe. It does not carry fuel. Engine vacuum pulls air in through the carbon canister, and it pulls out the fuel vapor that has been adsorbed by the carbon bed.
If either line taped to the EVAP solenoid is leaking, it creates a vacuum leak. But it shouldn’t cause the engine to die.
Here's what it is supposed to look like, at least on the 94-97 LT1’s. The 93 may be slightly different. In 94 the purge line runs around the front of the manifold, under the throttle body. 93 may be routed from the back.... or maybe someone hacked it up and ran the line from the back of the engine
http://shbox.com/1/evap_sol.jpg
Old Aug 21, 2019 | 05:48 PM
I rented a fuel pressure tester and it got 39 psi from priming it. I turned the car on and it stayed around the same when I revved it the fuel pressure would go up then go back down. I also just realized I have some cracks in the intake. They’re right by the throttle body. Idk if that could be enough to cause a vacuum leak to kill the car or not though. Also today I noticed a loud sucking noise with the car at idle as if it had a vacuum leak.
Old Aug 21, 2019 | 07:12 PM
The only harm is that dirty, unfiltered air is entering the engine. If it had an MAF sensor like the 94-97 LT1’s it would be a problem with air bypassing the MAF. But your 93, with no MAF sensor, runs speed-density, which calculates mass air flow based on RPM, manifold absolute pressure (MAP), and (absolute) inlet air temperature (IAT).
The torn inlet elbow needs to be replaced, but it isn’t causing the engine to die.
Fuel pressure sounds OK. If it runs, take it out on the highway and see if the pressure stays above 40 PSI at wide open throttle, over 5,000 RPM.
Old Aug 24, 2019 | 11:06 AM
I didn’t have a way to check the fuel pressure but while on the highway because the thing wasn’t long enough. I changed the fuel filter though and it helped a lot but it still occasionally does it.
Old Aug 24, 2019 | 11:11 AM
Pull the codes. Clear them. Next time the engine dies on the road, scan for codes again.
94z28cam
Jun 24, 2018 09:02 PM
alliance12364
May 1, 2011 05:53 PM
Camaroz28lt1383
Mar 19, 2009 02:11 AM
Sceanzo
Oct 14, 2006 06:04 AM
devilisht2003
Jan 31, 2006 04:01 PM
