Car cutting out- details inside
Old Mar 6, 2004 | 03:51 PM
BlackDog's Avatar
This problem will happen at any time while driving or revving it up in park. It really happens more at 5-6k rpm but also has happened while crusing.
The tach will jump around and it will light the ABS, brake and low traction in the dash.
What I've done so far is this:
Replaced opti, coil, ing. module, reflashed pcm with the stock file, checked the grounds with a meter, reconnected all connectors.
The problem sounds electrical to me but where?
Any ideas?
Scott
Old Mar 6, 2004 | 07:40 PM
BlackDog's Avatar
I found the problem.
It was the positive wire from the battery that goes to the starter it was melted and touching the header.
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
